I'm having a bit of trouble playing 1080p files on my computer. I have complete success with 720p, but 1080p skips on occasion. I think that my computer *SHOULD* be able to handle it. I have an nvidia 8800gt video card, and a intel core duo 2.00 GHz processor.
I'm beginning to think that maybe the processor isn't powerful enough to run 1080p smoothly, would it be in my best interest to upgrade it?
Results 1 to 9 of 9
That PC should be fast enough for playing HD content.
You should use a codec which can use the hardware playback (Purevideo) of your GT8800 card properly.
I personally use the Cyberlink/PowerDVD 8 ultra codec for HD playback.
With that powerdvd codec I even can play 1080P easily on my older P4 3,2 and GeForce 6610XL card
I've been using MPCHC. I tried going into the H.264/AVC (DXVA) settings and unchecking ffmpeg as I saw suggested in the thread that jagabo linked. It didn't change much but I think it's running slightly better. My cpu usage goes up to about 60% while playing the file.
Are there any other codecs in MPCHC that I should keep unchecked? I suppose I would invest in NVidia's purevideo as a last resort but I'd rather not have to spent the extra cash
60 percent indicates CPU decoding. DXVA would give you single digits. I seem to recall that some of the oldest 8800 cards didn't support DXVA. Did you verify the H264 decoder was set to 2 threads? Make sure you are using Overlay Mixer for output.
Playing 1080p video on a higher res monitor
By Long Hot Summer in forum Newbie / General discussionsReplies: 6Last Post: 8th Jan 2011, 05:25 -
No Dialogue Playing 1080p h.264 on PC
By Rickter Spatz in forum Newbie / General discussionsReplies: 5Last Post: 10th Aug 2010, 23:22 -
problem playing mkv x264 1080p
By ioio in forum Software PlayingReplies: 24Last Post: 10th Oct 2009, 21:33 -
Having trouble with converting mkv to mp4 in 1080p
By NoobyDoo in forum Video ConversionReplies: 40Last Post: 18th Jun 2008, 00:59 -
Playing 1080p video at 1366x768-does it downconvert to 720p?
By bigshotceo in forum DVB / IPTVReplies: 15Last Post: 28th Feb 2008, 15:54
