Anyone knows where can I get the modified firmware for Philips DVP5965k/98?
Does the modified firmware of 5960/12 or 5960/37 works in this model because I observed that this model had the same features including update feature of the official firmware of the 5960/37?
I don't know where to get it nor if it will work for your model, but what do you expect this firmware to do? The only modified firmware I've heard of for Philips did things like supported longer file names for MP3 and AVI playback or it supported some punctuation characters like accent marks that aren't used in English. If you are expecting modified firmware to do something else, you will surely be disappointed.
I would like to use the firmwares presented in site:
http://www.phunkyfish.com/article/4/philips-dvp-596012
I'm still doubtful to use it due to my fear that it may damage my player.
It is safe to use the firmwares from that site? -
The firmware at the site is probably OK, but there is no way to know if it will work in your player. It could ruin your player. I can't recommend that you do this unless you are OK if it ruins your player. I did a quick internet search and I could not find any information that suggests that this firmware will work on your player.
Philips BDP7500 firmware hack
By Sylph in forum DVD & Blu-ray PlayersReplies: 0Last Post: 28th Dec 2010, 15:05 -
Can Philips 5990 firmware be used on Philips 5992 Dvd Player
By peggypwr1 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2010, 17:06 -
Philips DVP5960 custom firmware?
By bluepassat in forum DVD & Blu-ray PlayersReplies: 3Last Post: 4th Jul 2008, 13:49 -
Philips DVP5960/12 Firmware 12.06.36.24 download it here
By F-Swed in forum DVD & Blu-ray PlayersReplies: 92Last Post: 11th Apr 2008, 22:48 -
Philips HTS3450/37 Firmware????
By ezdell in forum DVD & Blu-ray PlayersReplies: 2Last Post: 14th Nov 2007, 16:20
