Hello friends,
I have a problem, when I play a dvd movie with 5.1 channel sound. I get very low sound in rear speakers as compared to front and center speakers.
It happens in both Powerdvd 8 and windvd. I have onboard realtec 97 sound
and i am using creative inspire 5200 speakers.
Please help me to solve the problem..
Your kind help will be greatly appriciated.
From Control Panel start the Sounds and Audio Devices applet. On the Volume tab press the Advanced button in the Speaker Settings section. Make sure the system is set up for a 5.1 speaker system. Also press the Advanced button in the Device Volume section to start up the system mixer. Make sure the Back and Front sliders aren't maladjusted.
I don't use PowerDVD or WinDVD but make sure those are set to use a 5:1 speaker system, not downmix to stereo.
Use Realtek HD Audio Manager to verify the speaker connections. -
thanks for your prompt reply..
I tried what you said, but sadly it doesn't work. -
Sometimes I've noticed that rear output on computer surround sound systems isn't very strong. Even if they are powered systems it just doesn't crank them up.
I suppose one alternative is to get a seperate pair of powered speakers that can you can really crank up and use those as rear speakrs.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
You are aware that most movies don't have a lot of sound on the rear channels most of the time, right?
I have one of my rear surround speakers on an end table right next to my chair. The volume is always low as that's the way they are supposed to work. They are only to 'fill in' the sound, not to be an obvious sound source. The front center should be the loudest and the rear surrounds the quietest.
Most computer sound cards have a testing setup where you can check correct surround speaker operation. Or here are some files that should demonstrate surround sound: http://www.digital-digest.com/dvd/downloads/trailers.html
I don't notice the rear surrounds doing much except with a few DVDs that make real use of them. Try a DVD with THX sound.
Does 7.1 audio limit the rear speakers and divert to the side speakers?
By yoda313 in forum AudioReplies: 0Last Post: 4th Oct 2009, 10:55 -
Issues with Dolby Digital Sound (rear audio only for one chapter)
By ehmjay in forum MacReplies: 0Last Post: 20th Oct 2008, 10:55 -
Trouble with audio to rear speakers (off & on)
By heyjjjaded in forum Media Center PC / MediaCentersReplies: 0Last Post: 20th Apr 2008, 23:50 -
Best Sound Card and Speakers?
By therock001 in forum ComputerReplies: 8Last Post: 18th Jan 2008, 08:45 -
Audio speakers - TV sound
By sldub in forum AudioReplies: 2Last Post: 9th Oct 2007, 12:08
