I have an MKV file, contains H.264 codec, AAC audio and ASS sub. Tried playing it on VLC, plays fine, no lag, full speed, great audio, but didn't render the subtitle perfectly. Since ASS sub uses sub positioning and font style, it didn't appears so in VLC.
The sub displays fine in MPC. maybe because it uses fddshow, but the video lags when in fast moving scene (running, camera moving, credit rolling). Does this happen to you guys? or I messed up my setting? After installing K-Lite I didn't alter anything. And my pc is Athlon x2 4200, ATi HD3650, 2gb ram.
Do you know why people mostly use Mac in their office?
Because a lot of stress can lead people to jump off the "Windows". -
Get rid of K-lite. Use MPCHC instead of MPC (same look/feel, more built-in source filters and decoders, including h.264 and AAC). Set the h.264 decoder to use 2 threads:
View -> Options -> Internal Filters -> Transform Filters
Make sure H264/AVC (FFmpeg) is enabled. Double click on it and set Decoding Thread Number to 2. If your graphics card has hardware h.264 decoding try enabling the H264/AVC (DXVA) decoder intead.
If you insist on using the older MPC, make sure whatever h.264 decoder you are using is set up to use 2 threads. You can usually do this by right clicking on the video while playing, selecting Filters and selecting the h.264 decoder.
Cannot play avi file with vlc player/divx player or GOM Media Player (GAVC)
By texasdontholdem in forum Software PlayingReplies: 11Last Post: 5th Aug 2016, 08:28 -
Stream With VLC Or Windows Media Player Classic
By ZenMystic in forum Video Streaming DownloadingReplies: 0Last Post: 15th Oct 2011, 23:31 -
vlc or media player classic?
By Jorge in forum Software PlayingReplies: 30Last Post: 9th Aug 2011, 07:49 -
VLC vs PowerDVD vs Media player classic
By Abas-Avara in forum Software PlayingReplies: 1Last Post: 23rd Apr 2010, 13:42 -
Problem playing wmv files in Windows Media Player and Media Player Classic.
By rayden54 in forum Software PlayingReplies: 4Last Post: 1st Aug 2008, 23:49
