Hello,
I'm very new to this DVD to VCD ripping stuff. I was told to use:
SmartRipper 241
DVDx 1.6
VCDimage
Some of the movies copy fine, although it does take 6 hour per movie. I'm using a Pent 4 1.7 g with 512 mem. The CPU is at max the whole time.
The problem is while using SmatRipper, some of the DVD give me an error. ( Files locked ) Is there any way around this?
Also, is there a better, faster way of doing this getting the best quality I can?
Sorry to be a pest, we were all new at some point. :-?
Please e-mail a reply if you can.
Terabyt1@aol.com
I'm presuming you either using Windows2000 or WindowsXP, both do not have an ASPI Layer included, which gives both ripping and authoring programs a problem when attempting to access the hardware, you must have an operational and updated ASPI Layer installed.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
Oddly, I've never had any problem with Smartripper or CDRDAO working in XP, and I've never done anything special beyond the default installation. I would venture to say that Windows XP does install an ASPI layer if it detects a CD-recorder in the system? Thus, I would be interested to hear others' experiences in this regard.
kinneera, I don't know how it never happened to you, but just about EVERY user of XP I know of, asked me to send them ASPI Layer Installation, and they had a CDRW drive in their system.
XP installs a substitute for ASPI, but ALOT of old programs don't work with it, and among your defeault installations, you might have installed an ASPI with out even relieasing it.Email me for faster replies!
Best Regards,
Sefy Levy,
Locked MKV files, Multiple Instances of Explorer, PC Lag
By pushkin69 in forum Software PlayingReplies: 3Last Post: 9th Nov 2011, 22:22 -
Locked Folder
By dfisher052 in forum ComputerReplies: 3Last Post: 7th Sep 2011, 17:39 -
VHS Locked
By arcmusic in forum Newbie / General discussionsReplies: 4Last Post: 13th Jan 2011, 10:33 -
locked post
By jonnyD in forum SubtitleReplies: 1Last Post: 2nd Oct 2007, 10:34 -
Locked out of my router!
By Xylob the Destroyer in forum ComputerReplies: 4Last Post: 14th Sep 2007, 10:28
