HI There
I have an intermittent problem in that when I record DVB-TV (does not occur on Svideo), that there are
audio glitches in the audio path. If I listen to the programme (watch whilst recording) I do not hear the
glitches at all, but is in the mpeg file when playing it back.
It does not matter what channel it occurs on.
The TV card I use is AverMedia 007. I also have Hauppauge 1300, and it does not occur on this card.
If I move the Avermedia card to another system (I have 3 systems) the problem is prevalent on every
system. All systems have Asus motherboard, M3A, M2NXE, and M1. All processors are Athlon 5200+ and
it has been tested on both XP32bit and XP64bit. I have had the latest drivers loaded and has not improved
the issue at all.
I originally took this up with Aver Support, they say after 3 months analysis that they have no clue what it is.
Correct me If I am wrong, but, Video/Audio stream is basically taken from the card and stored on the Hard Drive
in otherwords, when recording, it is not passed through a sound card, or sound chip on the motherboard.
I have included jpeg image of 4 glitches analysed in Nero wave editor.
Can anyone assist on this at all.
Best Regards
John Cooper
Results 1 to 1 of 1
John F Cooper
recording 1080i from dvb-t usb tuner - best practices
By codemaster in forum DVB / IPTVReplies: 1Last Post: 15th Mar 2012, 03:10 -
Recording issues with LG DVB-T HDD/DVD Recorder RHT497H
By Geex360 in forum DVB / IPTVReplies: 1Last Post: 22nd Feb 2010, 10:43 -
DVB-t300 schedule recording problem
By sharkbite in forum DVB / IPTVReplies: 0Last Post: 23rd Aug 2009, 19:59 -
Automated recording from DVB receiver card (in Windows)
By Thrasher0815 in forum DVB / IPTVReplies: 1Last Post: 7th May 2009, 09:59 -
LG DVB-T HDD/DVD Recorder Model RH2T80 - Timer Recording Problem
By KillrByte in forum DVD & Blu-ray RecordersReplies: 10Last Post: 30th Apr 2009, 22:20
