I have two DVD video folders on my hard drive. The combined size is about 3 GB. I want to burn both of them to a DVDr. No menu is necessary. When one DVD is finished, the other should begin. I tried using TMPGEnc DVD Author and inputed each DVD folder, but it seems to recode during the authoring process because I can see frame by frame on the progress viewer. I don't want to recode. This shouldn't take any longer than just burning 3 GB worth of DVD, in other words, about 10 minutes. I tried inputing both DVDs into Nero, but I got an error message when I tried to input the second DVD. Any ideas how I can do this? Sure, I can use 2 disks and burn these in 10 minutes, but I want to burn both of these movies on one disk.
There may be a way to hack the VOBs together with PGCedit, but that's beyond me.
I'd just:
1) Extract MPEGs or elementary streams: using PGCdemux or Rejig or VOB2MPEG.
2) Reauthor: I use GfD. It makes a menu by default, but you can make it autostart if you prefer.
(You can just select the VOBs in GfD, but I'm not sure how it will work if a movie extends over several VOBs. Anyway, extracting compliant M2V and audio is safer and pretty quick.)
This will not reencode, no quality loss. -
Thanks for the clear info. I get what you mean. More involved than I thought, however, it is worth doing because I don't want to waste a disk. Even worse, is the weight and space that an extra disk takes up. I know somebody that cuts every other tine on an umbrella just to save weight.
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 19th Oct 2013, 23:25 -
Taking portions of multiple dvds and put them onto another
By ulremember in forum Authoring (DVD)Replies: 10Last Post: 4th Mar 2009, 18:07 -
Using nero to put 2 dvds onto 1
By pupa in forum Newbie / General discussionsReplies: 3Last Post: 9th May 2008, 22:14 -
Home video too big for DVD. How do I put it on 2 DVDs?
By Saaski in forum Newbie / General discussionsReplies: 12Last Post: 14th Jan 2008, 16:00 -
How to put DVDs on Zen Vision: W
By cali_n_alley in forum Portable VideoReplies: 2Last Post: 28th Oct 2007, 19:14
