How Do i Cut a movie in half so i can fit it on two disc's
With TMPGenc go to "File" => "MPEG tools" => "Merge&Cuts". On "Type" choose VCD or SVCD or other (it depends how was encoded your movie file)after so click "ADD" to add your blahblah.mpg file. Double click on your blahblah.mpg to see your movie and to mark where you want to cut your first half movie file and after click OK and save it with other name (example: movie1.mpg). Procedee the same to the second half (and save it as movie2.mpg).
DON'T FORGET: your second half movie must begins exactly where ends the first half.
You'll have two .mpg files for burn in two CD-R.
I hope help you.
AVI Cut
By JP in forum EditingReplies: 4Last Post: 6th Mar 2012, 19:12 -
Final Cut X
By Tom in HD in forum MacReplies: 1Last Post: 29th Oct 2011, 09:35 -
How I can cut TS files ?
By Torresinho in forum EditingReplies: 1Last Post: 14th Feb 2010, 15:15 -
how to cut....
By marlo in forum Newbie / General discussionsReplies: 3Last Post: 27th Jan 2008, 02:28 -
final cut express and final cut pro 6
By ednarophati in forum MacReplies: 1Last Post: 16th Jul 2007, 10:05
