I am looking for software I can use to capture DV and split it into scenes with date stamp like HDVSplit does for HDV video..
Is there a free solution out there that will do this?
If not, is there a free solution that will take existing DV Avi files and break them into separate AVI files by scene/date?
Thanks much!
Results 1 to 14 of 14
Ours will (see signature). Works while capturing or from existing files. Also comes with an Excel add-in that lets you create a log of the scenes including thumbnails taken every second or so. This lets you easily find a clip at a later date.
John Miller -
Ok, I've installed your software but I don't see how to break an existing DV avi file into seperate avi files based on scene / date...Originally Posted by JohnnyMalaria
Sorry if I'm missing it.. -
I found the scene detection option but it seems to only break my hour long avi's into the first three scenes and then stops..
IE: I will choose an existing 12gb raw DV avi file, it will run and create three separate avi files with appropriate dates, but then it will just stop.. It won't create the rest?
I did this with two different raw avi files and the results were the same. It created 3 avi files and then stopped processing. -
Hmm. That's not right...
Let me investigate with some one hour clips I have. BTW, are your files Type 1 or Type 2 DV AVI?John Miller -
Is there anything like Enosoft DV Processor for the MAC? How about Windows 2000?
Thanks... -
We don't have either, sorryOriginally Posted by brycebwalker
The software draws heavily on features added to XP for the FireWire stuff that aren't available in W2K.John Miller -
What I'm really looking for is software that will take existing raw DV video files I already have captured and break / split them into seperate avi's based on date.. I don't really want to have to recapture 10+ tapes again..
I should have put that in my OP.
New camcorder: HDV vs. AVCHD or DSLR like EOS 5D Mark II or similar
By flashandpan007 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 22nd Jun 2011, 15:09 -
Help with incompatible video format, HDV
By LaMaison in forum MacReplies: 6Last Post: 21st Dec 2009, 06:00 -
Best way to archive and view HDV video?
By sgrundy in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 9th Dec 2009, 00:21 -
Newbie looking for a video editing program similar to Windows Movie Maker
By Anonymous74 in forum EditingReplies: 3Last Post: 18th Sep 2008, 02:48
