update the windows build (later for linux)
added support for multi audio
BHH
Results 31 to 60 of 144
HDConvertToX, AutoMen, AutoMKV Developer
thx for this great tool,one question here.
is it possible to customize the ui font size, it's looks too small to me. -
some fixes for program path
better ffmpeg support
added support for NO video encoding (aka..encode only audio)
@richcine
(now) isn't possible
since i build fot both windows and linux i must use some fixed fonts size.. or the gui will be unreadable
BHHHDConvertToX, AutoMen, AutoMKV Developer -
thx, i got that. so it use gtk in windows, too?Originally Posted by buzzqw
www.purebasic.com (my programming language) use gtk for linux and native mfc for windows (so the executable are so small)
update to 0.13
update both builds, windows and linux
added support for encoding with x264 (via avisynth)
added support for decoding with avisynth (and encoding with x264) , using dgavcdec, ffmpegsource, directshowsource
added support for copy audio/copy video/no audio/no video
better encoding with ffmpeg
now autox264 is a multi encoder (x264/ffmpeg/mencoder) for h264 codec!
Continues to be a great product! Up to now I've been making h264 mp4s with no audio. I'm now adding audio and notice that it takes two passes of mencoder to generate first the video then the audio and then using mp4box to glue them all together. Is there an option to do it all in one pass? Is it possible to have some defaults for making good, better, best mp4 videos?
no, it's wanted as isIs there an option to do it all in one pass?
since i mux with mp4box (or mkvmerge) i need a raw video stream and a raw audio stream
i added support to megui profiles... try with it (or use a stronger denoiser)Is there an option to do it all in one pass? Is it possible to have some defaults for making good, better, best mp4 videos
hmmm... I'm not getting it to work (at all) now. First of all didn't it use to auto "Analyze" as now when I hit start it gives me the "Attention! Analyze file First" message?
Then when I click "Analyze with" I get the messages "Please, check autocrop value" (whatever "autocrop" is I don't see it on the page.) Then is gives me the same "Please, check autocrop value" again. Then it gives me a "unable to compute correct Aspect Ratio" (which I think you are calling "resolution") It then loads "interesting" numbers in the crop fields which I reset to "0" I then set the audio to MP3 Audio. When I run it and then try to play the video I get
this error: Error =2041: an invalid sample description was found in the movie (out.mp4) -
I'm baffled. What I did was after I ran autox264 I looked at the generated .bat file. What seems to be happening is that the mp4box is not pulling the audio in. I end up with a good "autox264.h264" file and what appears to be a good "audiox264-pidl.mp3" I discerned this by first running the mp4box.exe with just the .h264 file and it generated the .mp4. Then if I use quicktime to play the .mp3 file it plays and I hear the sound. BUT when using mp4box to add them together I get the following message.
URL??? This is the autox264 mencoder script generated for the audio pass and mp4box pass:Code:Opening file audiox264.mp3 failed Error importing audiox264.mp3: Requested URL is not valid or cannot be found
Can someone tell me what is wrong with these command lines? -thx-Code:"mencoder.exe" -mc 0 -noskip -aid 1 "wide'20081025 02.16.42.avi" -ovc frameno -oac mp3lame -lameopts abr:br=96 channels=2 -af volnorm=2 -of rawaudio -o audiox264-pid1.mp3 "mp4box.exe" -add autox264.h264 -fps 29.970 -add audiox264-pid1.mp3 "autox264_wide'20081025 02.16.42.avi.mp4"
yes, the 0.13 has changed a lot the interface
follow these step for encoding
1) load the file
2) hit analyze file (with mplayer)
3) if you use mediainfo on above, hit detect crop on main panel (on resize&crop)
4) check if crop is ok (you can use preview)
5) set the encoding parameters (audio video)
6) click start
the problem you got with mp4box is due to your output file name, don't use . or ' in output file name
on autox264 you can even NOT set the output file name, it will automatically named autox264_yourfile.mp4
Thanks. What I described two posts up the thread was the result of doing what you said. When I load the file and hit the anaylze file I get those error messages. I don't know what 'mediainfo' is.
In my previosu post I just shorten the file names actually the input file name is: wide'20081025 02.16.42.avi and the generated mp4 was named: autox264_wide'20081025 02.16.42.avi.mp4. I do see there is a ' in the name but it does work when I'm not trying to incorporate audio. -
Here's a smaller file (but still 40Megs) of the same format if you would like to try it. I'm probably missing something simple. (I hope so.) http://dl.getdropbox.com/u/134111/wide%2720081025%2001.07.27.avi
have you downloaded the "applications" pack ?
download it, unzip in a folder named "applications" (and not "applications\applications")
put autox264 in the same level as applications folder
and just for your information what is the character "wide'20081025 02.16.42.avi" between wide and 2 ?
Sorry I wasn't aware of the applications folder. I just downloaded the latest autox264. I will try that now.
Like I said the ' in the name has not caused any problems for me with video only. Are you suggesting that it is a problem when including audio? (Also I did a test by changing the file name to "test.avi" and got the same results. Were you able to run a test with the file I posted? Thanks for your help. -
yes! i had successfully encoded your sample (renamed to Wakewatcher.avi)
http://www.64k.it/andres/data/Varie/autox264_Wakewatcher.avi.mp4
just a note: in video filters, select "Deinterlace"
Thanks. I downloaded the applications pack and it looks like it is working. I'm not really understanding your comment about selecting 'Deinterlace' there are a lot of choices. It is set on none which should I choose? -thx-
select "Interlaced"
i mean you must De Interlace your video
so.. select interlaced
Hmm. Worked doing that but when I selected mp3 audio it still comes up with the Errpr =2041: when trying to run the mp4 file.
there is something wrong with the mp4box you use
please use this
http://www.64k.it/andres/data/autox264/MP4Box.exe
when playing using quick time with windows. I'm working on using acc as it seems to work.
Hybrid(Windows/Linux/Mac): Input -> x264/x265/Xvid/VP8/VP9
By Selur in forum Video ConversionReplies: 2462Last Post: 25th Apr 2026, 12:40 -
Fully working GUI video converter for Linux?
By danboid in forum LinuxReplies: 17Last Post: 6th Oct 2011, 21:25 -
Any hw accelerated h.264 encoder for windows like Elgato turbo.264 HD
By chicken264 in forum Video ConversionReplies: 3Last Post: 14th Apr 2011, 16:22 -
mkvextract gui not extracting h.264 viddeo stream
By kurian in forum Video ConversionReplies: 13Last Post: 21st Feb 2011, 11:14 -
DeVeDe - easy, batch capable video to DVD Linux/UN*X GUI
By danboid in forum LinuxReplies: 1Last Post: 23rd Oct 2008, 18:48
