update to 0.14 (windows for now)
added if input end with _1, autox264 automatically will try to load _2 _3 _4 and so on
added support for avisynt filters
added over twenty avisynth filters
added QMF support
added MVDegrain support
added colormatrix support
added greyascale support
added support for dgindex
fixed save path
fixed m2ts audio handling
reworked applications and filters path
BHH
Results 61 to 90 of 144
HDConvertToX, AutoMen, AutoMKV Developer
update to 0.15 (now only windows)
added tooltips
update package
BHHHDConvertToX, AutoMen, AutoMKV Developer -
update Linux build to 0.15 version
Hello,
first of all, congratulations for this nice program.
The main issue I have so far is with "set resolution" and "ar error". I see you're using mod 4, in theory that should allow lower ar errors. However, from a 1920*800 source, when I set width to 1280, gave a height of 520 and displayed an ar error of -0.0001, which is false, and since you use mod 4, it should have given 532. And if I set the height manually, it doesn't update ar/ar error (but it does if I set the width manually).
Also, having the option to save our profile (including the things in video filters and the audio settings) would be nice.
thank you -
Hi Goblack!
AutoX264 will follow ITU resizing, so.. if you don't want it, go in "Subtitle&Muxing&Encoding" and de-check "Follow ITU"
UPDATE: added manual to first page
EDIT: UPDATE windows build (0.15.127), now ar error is computed when height is manually changed
thanks
ar error is now computed, but ar itself still doesn't change.
About using Avisynth (DGAVCINDEX), that opens a cmd, then DGAVCINDEX window opens, and whatever I do next, it just gives errors in the console.
I think that as is, DGAVCINDEX doesn't support mkv, so I guess I have to demux the file myself and then load it in autox264, but if I do that, then I have no way to compress the audio with your application.
Am I getting something wrong? How are we supposed to use DGAVCINDEX with your program?
I will run more tests and edit this message if I realise I made a mistake somewhere.
edit: just checked a file I encoded with your program, mediainfo says psy_rd=0.0:0.0, while I set psy_rd=1.0:1.0 in the program. I used mencoder for that encode. I confirm that the command was passed as psy-rd=rd=1.0[1.0] to the encoder and that the output file has 0:0 according to media info. Has my file been encoded properly, as specified?
thank you -
DGAVCIndex doesn't support MKV, only m2ts with h264
for working with mkv you need to use or mencoder, or ffmpegsource, or directshowsource or ffmpeg
audio file could be encoded.. just open it as input file, and check "NO Video"
about psy-rd i will check too (btw i use avinaptic for analisys)
thanks for the quick fixes
Regarding psy-rd, what was the problem? Did the files get encoded properly?
I guess the only thing missing now is the ability to save settings (I don't mind editing xml files to create my own profile, but I see no way to select things such as resize filter/bitrate and other options, I have to enter those each time).
Also, do you intend to add support for other audio codecs (such as ac3)?
thank you -
psy-rd were simply not applyed
i will stick with standard MP4 codecs, so H264 for video and MP3 and AAC for audio.Also, do you intend to add support for other audio codecs (such as ac3)?
i don't think to change this (but as usually i changed my mind often..
i think Psy RD is still not working because of this
"psy-rd=rd=0.6[0.0]" i think it should be "psy_rd=0.6[0.0]" like this?
because i toyed around with psy rd strength and media info always give me this
"psy_rd=0.0:0.0"
or maybe the negative sign you put on psy-rd is actually a underscore?
im not that good in programming by the way just educated guesses there
this is a great program by the way its like batch recoder with power features ^^ -
yeah 0.15.139 build solve Psy RD
but the audio doesnt load for reencoding
can you fix it i think it has something to do with this parameter "-nosound" -
sorry pal.. i don't understud your problem
could you explain ?
ah sorry about that hehe
when i used your older builds like v0.15.122.1246 the audio can be encoded too like the video and the video and audio are muxed at the end of encoding and i can play it with both video and audio intact
but now with v0.15.139 the audio is nowhere to be found on the encoding process and when its mux there is no sound when playing the encoded file only the video -
dont know what happen but when i open the program again now
and queue it up there are 3 jobs (before it was only 2 the video and muxing)
thanks for the reply anyway -
maybe you select "No audio" ?
anyway.. glad you resolved
no i analyze it with mediainfo (not mencoder this time) and it becomes 3 jobs again
yeah thanks again nice x264 encoder -
hello, sorry to insist, but I've mentioned the option to save the settings twice already and you haven't replied, I take it you do not intend to add this anytime soon...
The way DAR is updated is unclear, it only changes with crop, doesn't show the new ar after resize, making it of very little use right now.
Another suggestion: since you use tabbed navigation, would be great to allow us to maximize the window, would display more tabs at once, making navigation quicker and easier.
thank you -
@Goblack
sorry pal but autox264 is a free open source software (FOOS) and is developed on my spare time
DAR is computed on AR and crop, resize don't change it
UPDATE: rev 0.15.142 (windows, linux will follow)
dar is now changed on ar change
save settings now save: resizer, muxer, denoise
HIDDEN save settings for:
Manual Bitrate
Deinterlace
these value will not be automatically saved (i don't want to make it "sticky"), BUT it in autox264.ini is present "Deinterlace = XXXX " , without quotes, and XXXX is the name of interlace filter to load, autox264 will load it at every start
the same for "Manual Bitrate = 1500" , in this case it will automatically load 1500 as manual bitrate
remember that : "Manual Bitrate" and "Deinterlace" isn't saved by hit "Save Program Path" , you must write it in automen.ini
BHH
P.S. as now isn't possible to maximize window AND display more tabsHDConvertToX, AutoMen, AutoMKV Developer -
thanks again and sorry if it sounded like I was putting pressure, I just wanted to know once and for all if something would be done regarding saving settings as I had already asked a few times.
I didn't know it was open source. I might contribute to it later.
edit: just tried the new version, I see we have to click on "save programs path" to save settings, I guess renaming that to "save programs path and settings" would be self-explanatory. Last thing, when you have some time would it be possible to add save settings for audio and Follow ITU (like disabling it)?
thanks -
update full windows package
addded in save settings follow itu
added eac3to support, now if input is mkv and users select DGAVCIndex as decoder, eac3to will be automatically called for demuxing video track (and audio too)
update all core sotwares
BHH
@Goblack
audio will not be saved (now)HDConvertToX, AutoMen, AutoMKV Developer -
wow, that was quick
now it gives negative height (right number, but there is "-" before it, so I guess it will be real quick to fix).
also, for subpixel refinement, is it normal that I have to set 6 in the xml to get 7 in the program? That would be starting at 0 vs starting at 1 I guess
nice update by the way
it's fun to see this program evolve
thanks -
negative height, example: I see 1280 for width and -532 for height, the new version of the application gives me negative (-x) heights for the resolution (including when first analysed and when changing resolution)
UPDATE (only for windows, linux will follow)
now preview will play even audio selected
@Goblack
PLEASE CHECK THE CROP VALUE, and the RESOLUTION BOX
something is very wrong on these values
i am able to replicate the issue only with a crop of full height...
update linux build to 0.16 (latest version)
Hybrid(Windows/Linux/Mac): Input -> x264/x265/Xvid/VP8/VP9
By Selur in forum Video ConversionReplies: 2462Last Post: 25th Apr 2026, 12:40 -
Fully working GUI video converter for Linux?
By danboid in forum LinuxReplies: 17Last Post: 6th Oct 2011, 21:25 -
Any hw accelerated h.264 encoder for windows like Elgato turbo.264 HD
By chicken264 in forum Video ConversionReplies: 3Last Post: 14th Apr 2011, 16:22 -
mkvextract gui not extracting h.264 viddeo stream
By kurian in forum Video ConversionReplies: 13Last Post: 21st Feb 2011, 11:14 -
DeVeDe - easy, batch capable video to DVD Linux/UN*X GUI
By danboid in forum LinuxReplies: 1Last Post: 23rd Oct 2008, 18:48
