i'm using dvdx1.7 and on the dvd i was doing 15 seconds into the movie it came up audio decoding error. it ask if i wanted to fill with audio buffer. I click on yes and continued when it was over i played it and for half the movie it had pauses in it every few second. how can i do the movie without the audio decoding error and what cause the error
thanks
DVDx simply has problems with some movies, I suggest you try using the DVD2AVI => TMPGEnc method instead, it may be 2 programs instead of one, but they do a better job in most cases.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
do you want to rip a mono movie? i got nearly the same problem with a mono movie and tmpenc does not help....
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 06:36 -
RipBot264 Audio Problem (no audio)
By fefalas in forum Video ConversionReplies: 9Last Post: 8th Apr 2011, 10:39 -
audio problem
By harariman in forum AudioReplies: 10Last Post: 7th Jan 2009, 21:31 -
problem with Audio
By cgguy in forum AudioReplies: 1Last Post: 14th May 2007, 06:48
