I have a subtitle file which I have made.Some of the subs are positioned at different positions.And some are overlapping.But when I play it back on media player and VLC,the subs dont appear like they're supposed to!I tried converting them onto DVD and it still won't display the way I want them to(as mentioned).The subs that I positoned at the top appears to be at the bottom and one of the sentences that is suppsed to overlap with another words dont appear.
How do I solve this?Someone help me.Please don't suggest to hardub because I dont like hardsubbing as it reduces the quality of the vid.
				Results 1 to 10 of 10
	I can't live without my computer.
	DVDSubEdit can re-position individual subs where you want them (top/bottom/etc).
	ASS then I convert it to SRT.Same thing.....Originally Posted by guns1ingerI can't live without my computer.
	SRT format does not support any formatting.Originally Posted by aruwin
 You can put some HTML-style formatting codes in them, sometimes it will display but it's not standard.
 If you want it to be pretty, use ASS.
	I already used ASS but the subtitles still won't play as formatted.They all appear like the normal subs that you see on tv.I have already positioned them butOriginally Posted by AlanHK I can't live without my computer. I can't live without my computer.
	I guess you need the vsfilter for ass filters to be shown correct. But I don't know any tool that can keep the positions when you convert to dvd switchable subtitles, the only method I know is to use dvdsubedit after as ZQX mentions.
	As Baldrick said, VSfilter is able to display .SSA and .ASS correctly.
 Use MaestroSBT for converting .SSA into .SST, which will be
 happily accepted by Muxman or DVD-lab PRO.
	I already have VSfilter.THat's why I thought it was weird that the subs dont display correctly.But I just found out that I didnt activate the active rendering settingsOriginally Posted by Midzuki Now I am able to watch the subs correctly Now I am able to watch the subs correctly
 But,there's one more problem.Conevrtxtodvd still won't display the subs correctly How do I force convertxtodvd to display the subtitles as formatted????
						I can't live without my computer. How do I force convertxtodvd to display the subtitles as formatted????
	aruwin: It's nos possible using convertxtodvd and problably NOT using any other dvd authoring program.
  MPC won't display on secondary monitorBy Monarch1st in forum Software PlayingReplies: 2Last Post: 17th Feb 2012, 13:11
  Video won't display in VegasBy Squid_uk in forum Newbie / General discussionsReplies: 13Last Post: 22nd Feb 2009, 13:29
  Zoomplayer won´t display DVD subtitlesBy fk in forum Software PlayingReplies: 2Last Post: 17th Oct 2008, 06:34
  DVD won't display as letterbox in standard TV 4:3By edong in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 1st Jun 2008, 12:48
  Phillips 5982 won't display jpgsBy wannabeswede in forum DVD & Blu-ray PlayersReplies: 1Last Post: 2nd Jan 2008, 08:26
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
