I plan to purchase light scribe disces as well as light scribe burner, just want to know if some dvd burner like Fly DVD Copier can recognize this kind of new media; I usually use it for normal discs and it works well, but the new media can write things the same ways as the normal disc? Is there anybody has the similar expierence?
Lightscribe DVDs are functionally the same as the normal types; they must adhere to DVDR specifications. The difference is on the top side of the disc, which contains a reactive dye. You put the DVD in upside down and the laser will, hmm, "print" a greyscale image.
You'll most likely get Lightscribe software with your new burner, if not, just do a search for it. It's free. Good luck.
Pull! Bang! Darn!
Video from light projector?
By Compo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 15th Jun 2011, 20:51 -
light scribe not working
By bnts1993 in forum Newbie / General discussionsReplies: 1Last Post: 10th Jun 2009, 15:41 -
ambi light prob
By Mr anderson in forum Media Center PC / MediaCentersReplies: 8Last Post: 9th Mar 2009, 13:01 -
Low-light shooting
By azinkin in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 17th Mar 2008, 16:12 -
Payable portable light?
By B-Twien Bytes in forum Newbie / General discussionsReplies: 2Last Post: 12th Oct 2007, 12:02
