Results 1 to 13 of 13
    Nov 2008
    Turkey
    ı there
    ı search lots of net sites but ı can t find any solution about thıs problem ı have lots of hdrips or bluray ı want to watch thıs videos on dvd ı mean ı want to convert hdrips to dvd ıf you know that please help
    thansk for helpp
    You will lose quality when converting to standard definition DVD. You can try ConvertXtoDVD, open the evo or m2ts from the hddvd or blu-ray and convert.
    Nov 2008
    Turkey
    thnaks for answer but ı used convertx but ıts not enough quality
  4. You can't keep the quality. You lose too many pixels scaling from 1920x1080 => 720x480. Furthermore, MPEG2 has lower compression than h264, while reducing the bitrate (trying to fit on a DVD5), and you are transcoding a to a lossy format - compounding the quality loss
    You can try FAVC which uses HCenc, it might be slightly better quality, but don't expect any miracles for the above reasons. Also try DVD9 which will allow you to increase the bitrate.
    Nov 2008
    Turkey
    fısrt thanks for answer but ı want ot say smthıng about quality when ı make dvds ı dıdnt change the video format ı mean ı use 16;9 but when ı start to convertx todvd program afterthat 4.7gb fıle converted to 2.8 because of that quality will decrease do u know any program whıch ıs not decrease the file valuo 4.7 to 2.8gb??
  6. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    FAVC will be more accurate than ConvertXtoDVD, however you will still notice a very large reduction in picture quality simply because you are cutting the resolution by over 75% and re-encoding to a much lower bitrate
    Read my blog here.
    Nov 2008
    Turkey
    thanks for answer but how can i convert without quality loss?
  8. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    I am not sure how many ways you can be told - you cannot. Period. No more discussion. Can't be done.
    Read my blog here.
    Nov 2008
    Turkey
    ok thanks for help
    Nov 2008
    Turkey
    but ı can t use the favc how can i learn it?
  11. Here's an FAVC guide:
    http://www.digital-digest.com/articles/FAVC_Video_to_DVD_Guide_page1.html
    And what's with all the "&#305"? It's pretty annoying. Can't you make it stop.
    Nov 2008
    Turkey
    oo thaks and sorry for 832gbj thıng
  13. Greetings Supreme2k's Avatar
    Feb 2003
    Right Here, Right Now
    roboroach, I know it may be a pain, but can you cut and paste your vowels on sites (or at least this one) that use a standard U.S. keyboard set? It seems as though your keyboard is outputting special characters that are not compatible with this board.
