    Nov 2008
    Hi. I'm trying to make a dvd with a simple menu. I have VOB files so I don't want to run it from another authoring program like Cyberlink PowerProducer and Adobe Encore in order not to loose any quality. Is there a program that will allow me to create a dvd with my custom image and insert 5 text links only on that image and just use my vob without reprocessing them?
    Oct 2005
    666th portal
    authoring programs don't usually re-encode if the input is dvd spec. they will want to de-mux into separate video and audio streams. there is no loss of quality in de-muxing, so you should allow that.
    find an authoring program to your liking. my favorite is dvdlab pro.
    Nov 2008
    I created the movie from my camcorder with Cyberlink PowerProducer but its dvd menu could not make my menu look the way I wanted to. I saved the VOB files from that and tried using it with Adobe Encore CS3. Which does not accept VOB files. So I had to convert them to mpg and then it re-encoded the files and there was a noticible quality loss. That is why I looking for a program that will just let me create the menu without playing around with the VOB files. I'm looking for a way to just include them in a video_ts folder like you would an image for a webpage after you wrote the code.
    Oct 2005
    666th portal
    a vob isn't dvd spec without the ifos and bups from the authoring program. you will need to redo it.
    check out the 30 day demos of dvdlab, tmpgenc dvd author, or any others on the tools/authoring(dvd) page.
    there is the freeware dvdauthor and gui on that page also.
    Nov 2008
    I have all the IFO and BUP files. I created a DVD folder without a menu. It would be very tedious to recreated the whole movie. Too many effects, clips and scenes. That is why I wanted an easier way out. I will try to progs that you recommended. Thank you.
    IF Encore rejected the files and re-encoded, then your PowerProducer output may have been set incorrectly, not to DVD spec.
    There are so many variables here.
    TDA would author fine, but only if the files are to-spec. And then TDA is limited in menu quality too.
