The Magnavox support center does not recognize model # MSR90D6 DVD Recorder. I was trying to find another original remote, but have read that it is small and hard to use. Can anyone recommend an universal remote that is easier to use that will work with this model?
If there aren't any universals, please help me to find the original remote replacement.
Any help is much appreciated.
If you aren't opposed to spending around a 100.00 for a remote control check out the programmable LOGITECH HARMONY series. Excellent remotes and you don't need a working original. Just setup it as a "setup for similar device" and you can plug it in.
Now of course you could buy them used for much cheaper on ebay or amazon or whatever.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Remotes.com has a replacement: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m1=MSR90D6&uuid=12272990767100
They've been recommended here before. -
Get a One For All 8910 for $20-$30. I haven't found anything it won't operate. They do need upgraded over the phone sometimes but it's an easy task.
These are the best. You could probably get one for $50 at amazon.com if it's on sale.Originally Posted by yoda313
Just plug it into your computer to get the codes, they have codes for 10,000 or more things.
Looking for original or replacement remote unit for Sonystar DVD636k
By aklo2001 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 1st Apr 2012, 07:12 -
Need help finding replacement for Cyberhome player
By canofhumdingers in forum DVD & Blu-ray PlayersReplies: 1Last Post: 22nd Mar 2012, 21:15 -
Replacement remote for Pioneer DVR 640H
By Chuck584 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 1st Jul 2010, 01:41 -
Help finding region code hack for magnavox nb500mg1f
By jswatkins in forum DVD & Blu-ray PlayersReplies: 2Last Post: 3rd Dec 2009, 22:09 -
replacement remote control unit
By pappy in forum Newbie / General discussionsReplies: 1Last Post: 4th Jan 2008, 12:25
