Hello, Geniuses! Just a quick question about removing unwanted images. I want to film several puppets and edit out their strings. Is there a way to do this like DeLogo, but can remove more than one part of a video at the same time? I have VDub and the Adobe CS3 Suite. Like your site, by the way.
If you have after effects in the CS3 suite then that would be the best tool. It has a tool that works in a similar manner to the clone stamp tool in Photoshop. Combined with the tracker it can simplify some of the wire-removal work for you. There are also plugins that are specifically for wire and object removal, but they don't come cheap.
Read my blog here.
I'll look into that. Thanks, Gunslinger!
There are no problems - only chances to excel.
-- Unknown
brighten only a portion of a video?
By magnumpy in forum EditingReplies: 1Last Post: 23rd Dec 2011, 01:00 -
trying to strip audio and save video portion only
By geminidreamer in forum EditingReplies: 3Last Post: 17th Apr 2011, 13:28 -
Hi ! How can I cut a portion from a video,and paste it to another?
By nightshift in forum EditingReplies: 20Last Post: 21st Nov 2010, 01:15 -
edit only a portion of audio in video?
By shun in forum AudioReplies: 1Last Post: 7th Aug 2008, 20:11 -
Possible Bad AVI with Missing/Lost Portion of Video
By PedX in forum Newbie / General discussionsReplies: 3Last Post: 17th Oct 2007, 14:18
