1st time encoding using H.264 with VirtualDub, during the 1st try...VirtualDub just crashed, went into X264VFW configue and saw there is a tick box for VirtualDub HAck (don't know what's that for) but selected anyway....2nd try (now), it's encoding but kinda slow down everything on my PC e.g. FireFox is opening slow, Windows is opening folder slower etc....from the task bar, is my H.264 encoding using only 1 core instead of 4 cores? (Q6600/4GB ram), or this is normal for encoding in H.264 with VirtualDub?
Thanks.
My understanding is that the Vdub hack is to "force" h264 video into the .avi container and allow b-frames to function
It works most of the time, but you should really consider using something else like .mp4 or .mkv as the container which are properly supported (vdub can't output .mp4 or .mkv, avidemux can)
It is easier to lower the process priority (in the processes tab in task manager, find virtualdub and right click it => set priority low)
But if you want to limit to 1 thread, the 3rd tab:; or adjust it to 6 if you want the fastest. #CPU cores x 1.5 is the optimal performance formula for x264. I think threads=0 is "auto", which defaults to 1.5 x #cores
Woot, thanks poisondeathray!
Didn't see the 3rd tab, now I will select 4 instead of the default 1 8)
I'm lost, how to use .mp4/.mkv and what's container? don't laugh...newbie hereIt works most of the time, but you should really consider using something else like .mp4 or .mkv as the container which are properly supported
No worries, don't be afraid to ask we are all trying to learn stuff here...Originally Posted by tigerb
Basically, there are different wrappers or containers that can hold different audio & video formats. Think of it as a box that holds video and audio. Each type of container has different specifications and has it's own pros/cons for different situations. Some are compatible with some software/players or audio/video codecs and some are not.
.mp4 and .mkv are examples different types of containers, as are .avi and .mov, and there are several others like .ts, .m2ts, etc....
vdub cannot export .mp4 or .mkv, but it can import the audio & video indirectly if you frameserve with avisynth, or use the directshow plugin.
avidemux can import and export both these containers -
Yes avisynth consists of scripting and very powerful, I'm learning new stuff and functions every week and still haven't even scratched the surface .
But learning curve is steep, but I highly recommend learning at least basic concepts because just about everything in video uses it in some form or another. Many of the gui's use avisynth in part of the back end operations.
http://avisynth.org/mediawiki/Main_Page -
Thanks for the link, perfect for newbie like myself :PYes avisynth consists of scripting and very powerful, I'm learning new stuff and functions every week and still haven't even scratched the surface .
Much appreciated!
Please help: slow megui encoding on Quad Core
By bremler in forum Video ConversionReplies: 8Last Post: 4th Mar 2010, 00:56 -
Quad Core Encoding, Xvid or X264
By kidcash in forum DVD RippingReplies: 20Last Post: 8th Feb 2010, 06:46 -
Enabling AVC Core in Virtualdub?
By drwho in forum Newbie / General discussionsReplies: 3Last Post: 3rd Nov 2008, 20:22 -
multiple core/cpu xvid encoding?
By lumis in forum DVD RippingReplies: 1Last Post: 17th May 2008, 08:38 -
stressing dual quad core with x.264 encoding
By xxxii in forum ffmpegX general discussionReplies: 1Last Post: 5th May 2007, 16:32
