What is the best program to convert mkv to DVD?
"The greatest tragedy in mankind's entire history may be the hijacking of morality by religion." Arthur C. Clarke
FAVC generally works and produces great results. If it chokes, extract and repack the mkv with just the video and audio and try again.
ConvertXtoDVD will convert pretty much any MKV faster than FAVC, but at an arguably lower quality.
Both will do it much faster than tmpgenc.Read my blog here.
I USED Xilisoft Video Converter Ultimate, it created a VOB file in five hours, I was able to play it by assigning that file to MPC, but when I created VIDEO_TS folder and put the file in it and then tried to open the folder using WinDVD it wouldn't play it, does that mean it wouldn't play in DVD players as well, do I have to rename the file to be playable because now it's named by the title of the movie?
Also before I started the conversion it said it would have 4.43GB so I set it to normal quality, but when it finished I got only 2.36GB, what's up with that? I guess now I have to waste another 5 hours but this time converting with highest quality...if it's over one-layered DVD I will use CloneDVD."The greatest tragedy in mankind's entire history may be the hijacking of morality by religion." Arthur C. Clarke -
Personally, I wouldn't use Xilisoft for converting anything, but to each his own. FAVC would have done the same job in around 2 hours (properly), and ConvertXtoDVD a little faster again).
Read my blog here.
What should I select for best results?
Wow, it estimates 9-13 hours to complete!
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
How to play MKV, MKV to AVI, MKV to DVD, MKV to Xbox 360 or Playstation 3
By Baldrick in forum Video ConversionReplies: 2Last Post: 8th Mar 2012, 02:45 -
How to convert mkv to ps3 viewable format maintaining mkv subs in new file?
By shuyinliquid in forum Video ConversionReplies: 2Last Post: 14th Dec 2009, 01:17 -
mkv question... many mkv files (with subs) into 1 mkv?
By 0okami in forum EditingReplies: 1Last Post: 24th Oct 2009, 00:45 -
DVD to MKV - MKV to VOB/DVD?
By pavista in forum Video ConversionReplies: 5Last Post: 14th Jun 2009, 06:31
