Hi, today I i tried to import a video , but it imported only audio track. I tried to reinstall but nothing. So i cant see anything just hear. Thx for any help
what filetype are you trying to import?
chances are you're missing the needed codec -
filetype is avi. I dont know if divx or xvid. BUT! importing worked before and now not? i have k-lite megacodecpack.
use gspot to see what codec it is
those codec packs have been known to interfere with each other
perhaps remove it and only install the codecs you actually need -
who knows?
maybe you changed something...
try a system restore if you can -
Hi, so i tried to resore the system , but nothing happened. I made that gspot screen for u.
and one more screen from virtual dub.
problem solved
seems like codecs were corrupted i downloaded djbcp codec pack and everyting is how it was thx for helping anyway.
Sony Vegas Pro 10
By av.sorong in forum EditingReplies: 16Last Post: 9th Oct 2011, 13:27 -
Help With Sony Vegas Pro 8?
By Olivia Bishop in forum EditingReplies: 9Last Post: 2nd Mar 2009, 17:20 -
Sony Vegas Pro
By Liquid9Kitty in forum EditingReplies: 2Last Post: 15th Feb 2009, 03:53 -
Sony vegas 8 pro help
By jaycool1995 in forum EditingReplies: 2Last Post: 31st May 2008, 14:58 -
By jaycool1995 in forum EditingReplies: 5Last Post: 28th May 2008, 08:02
