I have a dvd that came with Japanese subtitles. Instead of translating them, I found a script for it (in English). Is there a program I can use that will sync the text and video without me having to create timecodes for it?
Thanks.
If the subs come without the timecodes, you would have to create them.
Can you use just the timecodes from the other subs and substitute the text? Either way, it may be a bit of work.
But if those are the only subs available....
Realize that someone has to code all those subs by hand at some point anyway. It helps if you speak both languages. -
Originally Posted by architectofpain
Are the Japanese ones in a text format? If not, rip/OCR them. The text will be gibberish. Doesn't matter, as long as the times are there.
Then you can use Subtitle Workshop in translation mode, paste each line of the English script next to its corresponding Japanese translation.
Still a lot of work.
There may be shortcuts.
For instance, if you can turn your English script into a valid subtitle file (could do this in Excel, if you look at the formats), then you can use Subtitle Workshop's synchronisation tools to adjust the times to match the Japanese OCRed version.
But first have a look at sites like http://www.kloofy.net/ which may well have a English subtitle file already. -
The only subtitles for it at Kloofy are for the cut version. The Japanese ones are in .sub format. The version I need to create the subtitles for has about 30 minutes extra. I'll give both a go. Thanks!
MKV file sometimes syncs wrong with MPC
By Sc4rf4c3 in forum Newbie / General discussionsReplies: 2Last Post: 15th Feb 2012, 11:46 -
How do I convert DVD movie to DIVX w/o Audio Syncs problems
By peggypwr1 in forum Video ConversionReplies: 10Last Post: 1st Aug 2008, 17:22 -
Automatically split a video to 2 dvds
By cd090580 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 17th Mar 2008, 17:56 -
How can I automatically capture still frames of a video?
By SamScaff in forum Capturing and VCRReplies: 1Last Post: 13th Sep 2007, 19:28 -
What Tool: Type in subs while viewing subs from hardcoded video
By kpic in forum SubtitleReplies: 3Last Post: 6th Jun 2007, 19:29
