Like, you get a video file, and this file is not blocked.
Please, no h264 in-loop deblocking, but if there is no way to get a video file and reencode it to a different codec than h264 and the resulting video file has blocks, so I think my only option is reencode the video to h264.![]()
Like, I have two files, one is a DivX [DX50] file and the other one is an XVID. The first one (DIVX) I would like to crop (remove black borders) and re-scale it and the second one I just want to reduce its bitrate reducing it's size.
Any codec, like mpeg4 (libavcodec) or standard xvid (not from libavcodec) and please tell me about quantitizer values and if I need to use 2pass encoding.
Thanks and see ya!![]()
Closed Thread
ONE similar topic is ENOUGH. https://forum.videohelp.com/topic359735.html
Correct mencoder options?
By wl2776 in forum Newbie / General discussionsReplies: 0Last Post: 11th Mar 2011, 10:22 -
High-quality two-pass MPEG-2 encoder alternative to Mencoder?
By fvisagie in forum Video ConversionReplies: 5Last Post: 30th Apr 2009, 02:36 -
Mencoder config and and command line -vf options not working together?
By AlexGrim in forum DVD RippingReplies: 0Last Post: 1st Dec 2008, 12:00 -
mencoder options NTSC 29.97 -> PAL 25 fps with a/v sync
By menket in forum Video ConversionReplies: 3Last Post: 8th Oct 2008, 07:04 -
Tweaking mencoder options
By acid_burn in forum DVD RippingReplies: 3Last Post: 27th May 2008, 08:59
