  1. -Hey!-
    So, I'm trying to copy a VCD. I used Nero to rip the image, but when I try to burn the image, it never starts the burning process. This is the log:
    5:21:28 PM #27 mmc -1067 File ThreadedTransferInterface.cpp, Line 1394
    Invalid field in parameter
    5:21:28 PM #28 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1394
    Could not perform start of Disc At Once
    5:21:28 PM #29 Phase 38 File dlgbrnst.cpp, Line 1436
    Burn process failed at 2x (300 KB/s)
    5:21:28 PM #30 Text 0 File Scsicmd.cpp, Line 371
    SCSI not using temporary buffers
    20 out of 20 temporary buffers allocated
    I don't know what to do. Could someone please give me some suggestions. I've tried CDRWin, CloneCD, and DiscJuggler. They all give me similar errors. PLEASE HELP!!!
    -Thanks!-
    Eric
  2. have you tried extracting the .dat file(putting it on your harddrive) and then burning?
  3. -Hey!-
    Yes, I've done that. But then my DVD player thinks that it is an audio CD.
    Eric
  4. are you using a cdrw? i had the same kind of problem once cause i did a quick erase of the disk. it use to be an audio disk and it would be recognized as such. i hope that helps if not tell me i'll try to find a better answer...
