    Nov 2008
    I am trying to convert .asf video from Panasonic DVD recorder to Mac OSX compatible .avi format. When I try to convert, I get the following message in the progress info box:
    Encoding started on Wed Nov 19 16:09:48 CST 2008
    Using GNU internationalization
    Original domain: messages
    Original dirname: /sw/share/locale
    Current domain: mplayer
    Current dirname: /usr/local/share/locale
    MEncoder dev-CVS-030226-15:00-3.1 (C) 2000-2003 Arpad Gereoffy (see DOCS)
    AltiVec found
    Error: option 'oac' has no suboption 'lavc'
    Using built-in default codecs.conf
    Reading config file /Users/anitaber/.mplayer/mencoderExiting... (error parsing cmdline)
    FYI, I am able to convert to .mov format.
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Mine says:
    MEncoder dev-CVS-051126-18:35-3.3 (C) 2000-2005 MPlayer Team
    Apparently you are using a much older and/or custom version of mencoder, which may not be 100% compatible with the ffmpegX 0.0.9. Any special reason why you're not updated?
    Nov 2008
    Thanks for your help. No particular reason except that I had not actually used ffmpegx since, I think, 2004 but had probably installed an update to it but not updated binaries at some time. I had the x version installed and was having the same problem, so I installed the y version which said that I didn't need to reinstall the binaries. Clear as mud?
    Anyway, I reinstalled the binaries and now it works except I get no sound. I did notice that the binary mpeg2enc.intel is shown as a document whereas the old mpeg2enc was a text document if that matters. The process information file says that it doesn't find audio stream:
    Encoding started on Thu Nov 20 10:46:36 CST 2008
    Mac OSX static build for ffmpegX
    AltiVec found
    CPU: PowerPC
    success: format: 0 data: 0x0 - 0x1055858
    ASF file format detected.
    Too many video packets in the buffer: (1340 in 8390837 bytes).
    Maybe you are playing a non-interleaved stream/file or the codec failed?
    For AVI files, try to force non-interleaved mode with the -ni option.
    ASF: No audio stream found -> no sound.
    VIDEO: [MP4S] 320x240 24bpp 1000.000 fps 0.0 kbps ( 0.0 kbyte/s)
    [V] filefmt:6 fourcc:0x5334504D size:320x240 fps:1000.00 ftime:=0.0010
    Opening video filter: [expand osd=1]
    Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
    Opening video filter: [scale w=320 h=240]
    Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
    Selected video codec: [ffodivx] vfm: ffmpeg (FFmpeg MPEG-4)
    Forcing output fourcc to 58564944 [XVID]
    VDec: vo config request - 320 x 240 (preferred colorspace: Planar YV12)
    VDec: using Planar YV12 as output csp (no 0)
    Movie-Aspect is 1.33:1 - prescaling to correct movie aspect.
    SwScaler: using unscaled Planar YV12 -> Planar YV12 special converter
    videocodec: libavcodec (320x240 fourcc=58564944 [XVID])
    Writing AVI header...
    ODML: Aspect information not (yet?) available or unspecified, not writing vprp header.
    1 duplicate frame(s)!
    Flushing video frames
    Writing AVI index...
    Fixing AVI header...
    Video stream: 912.960 kbit/s (114119 B/s) size: 19582982 bytes 171.600 secs 2566 frames
    Encoding completed on Thu Nov 20 10:48:21 CST 2008
    Thanks,
    Anita
  4. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    If mencoder can't find an audio stream, then these ASF files should be converted with presets that do not use mencoder.
    To convert to AVI, you could try the DivX ffmpeg and XviD ffmpeg presets.
    Nov 2008
    Both of those presets worked. Thanks for helping a newby boobie. Now, my new MacBook Pro just arrived and I'm hoping everything works when I make the big transfer.
    Anita
