hello to everyone....!!!
Using dis guide i ripped my dvd 2 xvid
https://forum.videohelp.com/topic221896.html
this guide is really great...i got d amazing result..![]()
but i had a problem...i gone thru d whole procedures step by step nd got d (.avi) file without audio of size (1.09)..
but now wen i'm muxin audio nd video using nandub the size of d new file keeps on goin...it wen 2 approx (10gb) nd den i stopped d process...
Wat should i do...????
m i doin somethin wrong...
please help me out anyone...
i used autogk...i used fairuse bt was not satisfied..
so i thought to search out some forums nd finally got d guide here https://forum.videohelp.com/topic221896.html
as u r sayin i already did Choose video->direct stream copy in nandub but dan also d size keeps on goin, goin...
this is d step dat is der in dat guide...
If your using NANDub:
1-From the AUDIO menu, select the type of audio to mux with your video (AVI/WAV/MP3/AC3/OGG), etc). When prompted, browse to your audio file.
2-From the VIDEO menu, select VIDEO -> Direct Stream Copy
3-From the FILE menu, select FILE -> SAVE AVI.
4-Input a new filename and click SAVE.
5-Click OK. Your final AVI should be complete in a few minutes.
In d 3-... third line select FILE -> SAVE AVI is mentioned
which file i have to select...the 1 wid (.avs)extention it is showin...
please help me...
thanks..
DVD to XviD Conversion
By DJRumpy in forum User guidesReplies: 211Last Post: 30th May 2016, 23:18 -
Problem Opening h264 in VDubMod [MKV - XviD Conversion]
By catastrophe in forum Video ConversionReplies: 3Last Post: 1st Jul 2010, 19:13 -
Ripped dvd conversion to xvid/divx weird audio problem
By victoriabears in forum Video ConversionReplies: 1Last Post: 12th Feb 2009, 14:41 -
Xvid to DVD conversion
By Meriks in forum Authoring (DVD)Replies: 5Last Post: 5th Apr 2008, 11:43 -
XVID AC3 TO MP3 Conversion problem help!
By sere83 in forum Video ConversionReplies: 4Last Post: 3rd Nov 2007, 15:55
