I'm currently using my father's Nero 6.6. I'm ok with the video aspect of it, but I am concerned about the audio bit rate. I am recording AVIs onto a DVD and these AVIs are intentionally set at an audio rate of 320kbs. After I put it onto DVD using Nero, is there anyway to check to see if Nero has changed the audio bit rate?
thanks
Yes, you can do this. IFOEdit can do it and it's what I'd use, but if you're not familiar already with how to use it you'll need to find a guide. Or you could just keep opening VOB files until you find the main one for your movie and hopefully you'll understand how to read the output.
Tools like GSpot and similar programs can probably do it. For reasons I don't understand, some tools that can report audio bit rate don't report the true bitrate but some weird figure derived from taking the audio bitrate and dividing it by the number of channels, so 2 channel audio at 320 Kbps might get reported as 160 Kbps or maybe something bizarre like 154 Kbps (some tools give really weird results here that can't possibly be correct). That's why I use IFOEdit for this kind of thing - it reports a correct, human readable value. -
I tried that and it lists no other info on the audio other than that it's dvd lpcm or something to that effect.
LPCM has a fixed bit rate of 1536 Kbps, so yes, Nero is changing your bit rate if it is producing LPCM audio. LPCM audio is identical to the source, but it takes up a lot of space so unless you video is 1 hour or less, it's generally not a good idea to use LPCM. I'm guessing that you may not have purchased Nero's plugin for producing AC3 audio, so that's why you're getting LPCM.
thanks jman, where can I get nero's plugin for producing AC3 audio?
thanks
Changing audio frame rate?
By architectofpain in forum AudioReplies: 22Last Post: 5th Apr 2013, 11:27 -
How to reduce Audio Bit Rate
By mad_mackem in forum Video ConversionReplies: 6Last Post: 28th Dec 2011, 10:30 -
Does changing frame rate make audio out of sync?
By aznbennet in forum AudioReplies: 2Last Post: 11th Sep 2011, 03:32 -
How to achieve the maximum bit rate in variable bit rate mode ?
By Sxn in forum Newbie / General discussionsReplies: 42Last Post: 3rd Dec 2009, 13:53 -
audio bit rate showing in video
By soulman1015 in forum Newbie / General discussionsReplies: 2Last Post: 20th Nov 2009, 11:44
