    Nov 2008
    not had a problem before but now when i burn a dvd the film will pause for 1 sec and then play for how ever many mins then pause again all the way through .i have tried burning at a lower speed ,using differnt discs ,differnt burner and software but still the same .if you watch the iso image on pc it is fine but when on disc it pauses and at the exact same point on every copy .has anyone got any ideas to try now ?
    Apr 2004
    Miskatonic U
    What is the source ?
    What software have you used ?
    What brand of discs ?
    Is this every film, or just the one film tried several times ?
    Read my blog here.
    Nov 2008
    the source is xvid
    i used dvd flick to make the movie and burn ,also burnt with imgburn and magiciso all the same but when image is mounted in to daemonits fine
    i have used an unbranded disc ,a datawrite and titanium dvd-r's it has been the last 2 films i have done
    and used a pioneer and a sony burner all with same results
  4. Mod Neophyte redwudz's Avatar
    USA
    Are you sure it's not a playback problem? What are you playing it back on? The computer or a set top player?
    Your problem sounds unusual. If you have ruled out the media, the software and the burners, not much is left.
    And welcome to our forums.
    www.nomorecoasters.com -- Your media does not sound like its quality.
    Nov 2008
    played disc on pc and it played ok so tryed on set top and still pauseson player ,so tryed on another set top player and it works fine time for a new player .just got to wonder what to go for in a new player ?
    thanks for the help
  7. Mod Neophyte redwudz's Avatar
    USA
    Some players (And burners) don't like some brands of media. And some older set top players may be a bit more 'picky' with newer media. Or the player may just be getting old and tired. They don't make most of them to last.
