Hello!
I need help to find a tool that can convert .yuv file to .ts (mpeg4).
My problem are that i got manu .sgi files that are just framegrabs and I found
that they can be convertet to .yuv.. Maybe you have a clue to make the .sgi files or
my sgi convertet to .yuv to a movie file .ts ?
thx.
Or you can use the Rawsource http://avisynth.org/warpenterprises/files/rawsource_25_dll_20060728.zip plugin for Avisynth to process YUV files.
JPEG to YUV
By mma238 in forum Video ConversionReplies: 20Last Post: 3rd Apr 2011, 12:53 -
Convert from YUV to h.264
By Comrinec in forum Video ConversionReplies: 1Last Post: 24th Mar 2011, 11:07 -
AVS to YUV
By fidogenial in forum Video ConversionReplies: 1Last Post: 21st Oct 2010, 22:53 -
Is there a way to revert "convert to YUV" did with RGB2YUV Palett
By Talayero in forum SubtitleReplies: 3Last Post: 29th Sep 2009, 07:57 -
YUV viewer
By mourya in forum ProgrammingReplies: 0Last Post: 31st Oct 2007, 14:38
