Since I am still on a learning curve I am wondering if there is a fix for this problem. I seemed to have acquired a very good quality Animal House AVI but the sound is off from the picture, is there a way to fix that with something like virtual dub? or is it a helpless situation and cannot be fixed, essentially when I play the avi on Something like Divx Playa or Real One Player the sound is off from the picture. I hope I have done enough to describe this simple problem.
Thanks again!!![]()
VirtualDub - fixing bad frames with blending and without re-encoding
By spicediver10191 in forum Video ConversionReplies: 3Last Post: 11th Apr 2012, 08:15 -
fixing <i> tags while encoding (VDM) - [solved]
By NeoTrix in forum SubtitleReplies: 0Last Post: 22nd May 2010, 14:24 -
VirtualDub - Editing and Fixing Sound
By bpatters69 in forum EditingReplies: 1Last Post: 26th Oct 2009, 12:33 -
avi to mpeg -> no more sound
By myk in forum Video ConversionReplies: 22Last Post: 14th Mar 2008, 12:15 -
Fixing muffled sound on .avi file
By kman0199 in forum AudioReplies: 1Last Post: 7th Jun 2007, 00:40
