I convert alot of mkv files to vob(mpeg) with the program mkv2vob. The problem is that the files often are over 5 gb, so I wounder if there are any program that can split this type of file to two or three files without loosing quality. I still want them to be in 720p or 1080p.
Thanks, but this program seems a little complicated. Any other?Originally Posted by poisondeathray
It's pretty much the easiest one to use:
Use ">>" and "<<" to navigate keyframes (e.g. fast forward, reverse) - you can use the slider to drag to move faster, but the ending cutpoints should be on a keyframe.
Use "[" and "]" to mark begin/end segment markers to highlight the section you want
File=>save this clip
All it does is copy that segment
Another option would be to split the mkv file first before your conversion, using mkvmerge
Cheers
AviSynth Script: VOB Splitting help
By PsyCLown in forum Video ConversionReplies: 15Last Post: 15th Apr 2012, 19:21 -
Splitting VOB files with audio delay/quality loss?
By S0VIET in forum Authoring (DVD)Replies: 8Last Post: 30th Oct 2010, 21:48 -
Splitting and Joining then Converting VOB > MPG > FLV
By deportu in forum Newbie / General discussionsReplies: 7Last Post: 12th Jun 2008, 21:32 -
VOB editing before burning (splitting, chapters, etc)
By windranger in forum Newbie / General discussionsReplies: 7Last Post: 3rd Nov 2007, 08:29 -
splitting an mpeg-2?
By php111 in forum Newbie / General discussionsReplies: 3Last Post: 17th Aug 2007, 18:18
