My gal pal has a Light Scribe burner and wants to engrave a disc. However, the installed L.S. software won't comply. Can she etch a non L.S. disc with any available freeware out there?
So the disc is a plain old dvdr with a normal surface? Than the answer is no. If they are PRINTABLE dvdrs than you can use a printer that accepts printable dvdrs.
If they are plain old dvdr the only thing you can really do with them is use a plain old sharpee. Sorry.
of course you could always go and buy real lightscribe discs and COPY the data to it. Then you'll be able to use the lightscribe feature on the copied disc.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Lightscribe software ONLY works on Lightscribe discs. NO EXCEPTIONS.
I don't think "etch" is the correct word. This means "to cut, bite, or corrode with an acid or the like". Lightscribe simply uses a laser to print to a Lightscribe disc surface, but it's not a true etching process. -
No, because the lightscribe dvdr surface is special, it's not just any plain old surface.Originally Posted by Scooter_NJ
It's like asking if you could use regular paper to replace carbon paper & still expect to transfer from one sheet to another to make a carbon copy.
Scribe Transcription Software
By devilcoelhodog in forum SubtitleReplies: 0Last Post: 27th Sep 2011, 18:02 -
burning and playing blu ray/hd content onto discs onto dual layer discs
By julie_152 in forum Authoring (Blu-ray)Replies: 18Last Post: 21st Sep 2009, 14:36 -
light scribe not working
By bnts1993 in forum Newbie / General discussionsReplies: 1Last Post: 10th Jun 2009, 15:41 -
Will 720P and 1080P dvdr discs play on a Non Blu Ray DVD Player?
By donfm in forum Newbie / General discussionsReplies: 21Last Post: 31st Mar 2008, 15:45 -
Any recommendations for players that will play dvdr dual layer discs?
By vinland in forum DVD & Blu-ray PlayersReplies: 9Last Post: 22nd Oct 2007, 04:02
