  1. Member Mr anderson's Avatar
    Jan 2004
    hi all, i am trying to remove some unwated sofware. ive tried using the add and remove that is within windows and it still leaves traces of it there. is there any other programs out there that will work?
    many thanks
    Feb 2004
    you could try Revo Uninstaller ? http://www.revouninstaller.com/
    I've used it with some success in the past.
    Good luck
  3. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Just about any decent registry program will can also handle it.
    EasyCleaner can do it ( http://personal.inet.fi/business/toniarts/ecleane.htm#download ) and I believe Ccleaner can do it as well ( http://www.ccleaner.com/ ).
    Google is your Friend
  4. Member Xylob the Destroyer's Avatar
    Sep 2004
    Earth, for now
    search your hard drive for all files named sysoc.inf (enable hidden files etc)
    open each in notepad and use the edit function to replace all instances of the word hide with nothing at all -- delete every instance of 'hide'
    save the file and go back into Add/Remove programs to see if there's anything "new" that you missed.
    the registry cleaners already mentioned are definitely a good suggestion and will go a long way
    sometimes after an uninstall and the above methods you will still find that you have to go in and manually delete stuff though.
    "To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
    "Megalomaniacal, and harder than the rest!"
