  1. Member videocheez's Avatar
    Jan 2003
    On my laptop I have no problems but on my desktop, I have not been able to view some wmv files. See below for the avicodec info. on the wmv file that I have been having troubles with.
    Video : 97 MB, 1205 Kbps, 9.790 fps, 640*480 (4:3), WVC1 = Windows Media Video 9 Advanced Profile, Supported
    Audio : 3.90 MB, 48 Kbps, 44100 Hz, 2 channels, 0x161 = Windows Media Audio 9.2, , , Supported
    Any help will be appreciated.
    Thx in advance,
    VC
    This is so much fun!
  2. Member zoobie's Avatar
    Feb 2005
    Florida
    see if it plays in VLC
    Oct 2005
    666th portal
    does the desktop have the latest wmp 11 installed?
  4. Member yoda313's Avatar
    Jun 2004
    The Animus
    Just out of curiousity these aren't drm'd wmv's are they? Could the licenses have expired?
    If these are run of the mill wmv's than you should try vlc and mediaplayerclassic.
  5. Member videocheez's Avatar
    Jan 2003
    Duh. I didn't think to play it with VLC. Thanks it worked. No luck with media player classic however. I don't like VLC too much because when I fast forward it takes a a few seconds to unpixilate. Thanks for the advice anyways. I don't know which version of windows media player I'm using. I still get a pop up one in awhile that says would you like to upgrade media player and i keep on saying no thanks. I don't think the videos i'm looking at are DRM'd.
    Thx all for the advice,
    VC
    PS. If anyone has idea why media player won't play these wmv's or how to determine which version of media player I'm using, I'm still open for suggestions.
  6. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    To determine the version of Media Player you have, go to Help > About... (should probably say "About Windows Media Player," or something like that, but I'm not sure it's the same across all versions. ) It should mention what version it is in the information that pops up.
    You'd think Media Player would automatically download any necessary support for a WMV file, though. You haven't installed any codecs/codec packs that might conceivably interfere with Media Player/DirectShow playback, have you?
  7. Member videocheez's Avatar
    Jan 2003
    I have WMP 10 and have installed no codec packs. I think your onto something regarding a codec that may be conflicting with WMP 10.
