Ahoy-hoy,
I recently replaced my DVR as, in the end, I could not finalize any of the DVD's. I recorded a lot of important footage (well, important to me, at least) and DVD Decrypter will not read the discs. Is there any possible way to access the VOB files and copy them over to my hard drive so that not at all is lost?
Results 1 to 10 of 10
I've never had success with anything software-wise, you must find a machine to do it.
You could also try Nero InCD, it often helps to 'see' vro files from DVD recorders. Its free, so maybe worth a try..
http://www.nero.com/eng/tools-utilities.html -
I'm one of the lucky ones with respect to the free version of ISOBuster. I've been able to recover video from unfinalized DVD-R and DVD-RW disks, recorded in video mode. I right click on Track1, in the left-hand pane, and ask it to extract the user data from Track1. That transfers everything on the disk as one large file. If renamed to .mpg, Power DVD can play it. VOBEdit can demultiplex the file as is. I have no difficulty editing the demultiplexed files, or multiplexing them again to produce a normal .mpg.
No DVD recorder that I have heard of produces subtitled recordings. I know for a fact that VLC doesn't display closed captions, which are often confused with subtitles, and which some DVD recorders can capture. I think you have misunderstood the point of the thread. We're talking about recovering video from unfinalized DVDs originating from a stand-alone DVD recorder. We are not discussing how to view or extract video from an ISO pulled from a DVD made by some other means, that has another problem requiring data recovery.
I have an OEM version of PowerDVD 5.0 that came with my LG burner. That version works for me. VLC will play nearly anything and seems to ignore file extensions when determining how to play the file. Some people will find it to be a good choice for their needs, but since I don't need VLC's special abilities, I don't use it, and have not tried it for this. -
Hi!
Sorry for being naive but my JVC DVD recorder recently broke down. I have some DVDs recorded by my JVC recorder which have not been finalised...
1. Am I correct to think that another brand DVD recorder, say, Sony, will not be able to play those DVDs nor finalise them?
2. If so, is there no way to finalise those DVDs apart from have my JVC recorder fixed?
Thank you in advance for any help.
Unplayable DVD because it wasn't finalized properly
By susaninpdx in forum DVD RippingReplies: 32Last Post: 18th Oct 2017, 08:11 -
Play non-finalized data dvd?
By julius_zombie in forum Newbie / General discussionsReplies: 1Last Post: 18th Nov 2010, 06:46 -
how do i edit a video dvd that has been finalized
By colekun in forum EditingReplies: 5Last Post: 19th Apr 2009, 15:00 -
Rip Video from un-finalized DVD on my PC? HELP!
By wayho in forum Newbie / General discussionsReplies: 3Last Post: 21st Apr 2008, 13:28 -
Cannot copy finalized DVD-RW from Standalone?
By jaggerdss in forum Newbie / General discussionsReplies: 33Last Post: 28th Mar 2008, 19:33
