Hello all:
I converted some tv shows that were in dvr-ms format to XVID with WinFF. They look and sound perfect on my computer but when I play them with my Linksys DMA2100 media extender I get no sound except a little chirp every now and then. Anyone else had this problem or now what might be the problem?
Well, it looks like it's the internal ffmpeg codec "libmp3lame". Here is the audio line from the winff preset;
-acodec libmp3lame -ar 48000 -ab 128k -ac 2
I am thinking that my dma 2100 can't read the output from this codec. I don't know what you mean when you say to copy the audio if it's ac3.
I know a little about all this but I'm no expert...that's why I'm using winff!!! What a great and simple program.
I was thinking i could try to use lame_enc.dll, so I put the dll in the same folder as winff and substituted it for libmp3lame in the command line preset. But that didn't work, ffmpeg couldn't find lame_enc.dll. Kinda stuck here........ -
By copy I mean that you will not reconvert the audio, just leave at as ac3 in the avi. Change the preset to "-acodec copy" instead of "-acodec libmp3lame".
Or try change to -ar 44000 audio and see if it works better. -
I tried to copy the ac3 audio but wound up with a file that was 190MB out of a 54MB scource file....everytime explorer went to that dir it crashed had to delete it in safe mode. I tried 44000 but that must be a unworkable bitrate and the encoder wouldn't do anything...i tried 44100 and it did encode but still will not play through the extender. mmmmmmmm.
Screen Captured vidoes always lag when played back.
By techspark in forum Capturing and VCRReplies: 2Last Post: 27th Apr 2012, 19:50 -
StaxRip produces artifacts when played back in MPC
By Xavier in forum Video ConversionReplies: 7Last Post: 29th Oct 2010, 11:19 -
Overscan on DVD played back on a computer
By maeks84 in forum Authoring (DVD)Replies: 6Last Post: 21st Feb 2008, 09:02 -
Erros at and of DVDs when played back
By ronknights in forum Newbie / General discussionsReplies: 5Last Post: 6th Feb 2008, 12:18 -
DVD sound is terrible played back on stand alone players
By nikoz in forum Capturing and VCRReplies: 0Last Post: 12th May 2007, 19:13
