When I edit my home DV movies, I have been using Motion DV from Panasonic to capture and edit, then TMPGEnc, then GUI for DVD to author, etc.
I have used Virtualdub often when I was converting VHS to DVD.
Today, a section of a captured AVI file was too dark. I used to VD to increase the light, using the Panasonic Codec to compress in VD. This causes a problem if I want to load that section and Motion DV closes. Any other one that I can consider??
I would try WinDV to do the FireWire transfer, then the Cedocida DV Codec and frameserve the VirtualDub output directly to TMPGEnc to avoid creating a in-between file. The Cedocida DV Codec works a lot better for me than the Panasonic.
I have a problem with mp4 files in virtualdub, slow motion audio.
By barbur in forum Newbie / General discussionsReplies: 5Last Post: 12th Feb 2012, 13:16 -
Rebuild JPEG Motion Video for play in Panasonic Lumix Camera
By RL in forum ffmpegX general discussionReplies: 0Last Post: 16th Dec 2011, 11:16 -
Virtualdub-like slow motion for x264 clips?
By spinmonk in forum EditingReplies: 15Last Post: 19th Sep 2009, 12:33 -
Divx Bitrate Adjustment - Low Motion or High Motion? TmpgEnc Xpress 4
By Sliztzan in forum Video ConversionReplies: 5Last Post: 31st Aug 2008, 20:11 -
How Do I Put A Custom, Created Slow Motion Clip Back In? (Virtualdub)
By WishMaker in forum EditingReplies: 8Last Post: 24th Oct 2007, 11:14
