hi, this is my first attempt to edit video of an sort. i have a film that is cut into two ~500mb parts and i am trying to join them without re-encoding. unfortunately, there is a ~2sec overlap. i used avidemux to append the second part to the first, but then i realized that a couple seconds repeats. what is the easiest way to edit the overlap out? should i try to trim the second part? is there any way to do this exactly so the two parts will match up perfectly? thanks.
	It should have done very minimal re-encoding - only at the cut and join GOPs - however given the age of your system I would be guessing you only have a single drive as well, so 10 minutes would be about right. The bulk of the time is simply data copying, and that is pretty much software independent. Read my blog here.
	ok. i am sure it is also slower on my system since my (single) drive is a 1.8" 4,200. (i love my fujitsu p7120)
 one more thing-- the files size dropped 20-30mb, even before trimming. seems odd since i was just copying.
	Combining files will reduce some overhead data because you won't need all the header info from the second file. Also, if you enabled Smart rendering and took the default Quant value of 4, some 300 or so frames will have been re-encoded at a potentially lower bitrate than they previously held. if you joined first, saved, then trimmed, you will have re-encoded this section twice in this manner. Better to join and trim in a single pass so you only re-encode once. Also, reduce the quant to 3, or better yet, 2 and you will keep the quality you started with (although you may add a few MB to the final size) Read my blog here.
	cool. that is exactly how i did it, actually. (trimmed the first part, appended the second part, saved with a q-factor of 2). i guess the overhead is just that large. good to know.
  [VirtualDub] How to split avi to x parts with one operation?By ralf07 in forum Video ConversionReplies: 3Last Post: 5th Apr 2012, 18:01
  Help!! Joining vidoes so thaey overlapBy chetan121212 in forum EditingReplies: 1Last Post: 26th Sep 2011, 23:31
  blot out parts of a avi videoBy isogonic in forum EditingReplies: 3Last Post: 18th Oct 2008, 19:53
  joining 2 parts of a DVD?By Itsmeshane in forum EditingReplies: 1Last Post: 23rd Oct 2007, 05:20
  Joining a movie with 2 parts together using virtualdub!!!By SaM*T in forum EditingReplies: 1Last Post: 17th Sep 2007, 15:09
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
