This may be a dumb question but I have an 83 min film I'd like to squeeze onto an 80 min disc. Tried overburing but my dear old writer couldnt handle that!
Decided if I could increase speed by about 4% this may work & you shouldnt notice such a small increase - but cant find an app that can do it ??
Any ideas ?
Thanks in advance
Glenn
Bad idea. You can speed up the video by increasing the framerate, but then the dvd player wont be able to play it. Cut 3 minutes or reencode at a lower bitrate.
Cheers mate. Whats the best/quickest app to lower the bitrate with ? Bearing in mind its an 800+MB file it could take quite a while!
Thanks again -
Dont know, what is the best, because you will loose quality anyway. Try TMPG. Fastest encoders are probably LSX and CCE.
Can you cut out any of the beginning or end of the MPEG. Cause to lower the bitrate you need to re-encode it.
Already cut it down as much as I can - will give bitrate compression a go. Thanks alot
One trick I just discovered is to load your mpg file thru TMPGEnc's 'mpg tools' as if you were going to cut it, but don't actually cut anything and run it thru. For some reason, the final mpg file looks identicle but is smaller in size. I have NO idea why, but it did at least on my last movie. It shrunk an 845MB movie to 765MB. Worth a try.
How do I change the speed of an MPEG movie file?
By mizpulp in forum EditingReplies: 17Last Post: 1st Oct 2011, 15:44 -
DVD software to speed up playing a movie?
By Haopengyou in forum Software PlayingReplies: 6Last Post: 28th Aug 2009, 07:36 -
Rendering taking too long- How to speed it up? (Sony Vegus movie)
By Entry in forum Newbie / General discussionsReplies: 9Last Post: 18th Aug 2009, 00:47 -
Need more help with Vegas Movie Studio Platinum 9.0 Speed up/Transparancy
By AlrauneTB in forum EditingReplies: 1Last Post: 23rd Apr 2009, 19:56 -
magix movie edit pro 12 burning speed problem!
By SKATEBOARDEDITOR in forum Newbie / General discussionsReplies: 6Last Post: 14th Dec 2007, 03:47
