I've got a clip someone downloaded to MPEG from Youtube I need to incorporate in a video for them. The original clips plays fine but when I bring it into Vegas it freezes and green blobs show up all over. Anyone had this experience before or know anything I can do to make it work? I'm attaching a screenshot from gspot showing the file info. It's a h.264 MP4 so I know it's not the least bit ideal but as I said, I was sent the video and had no control over the format.
Media Info will probably give you better information, but my reading of g-spot is that the use downloaded the file as an mp4, and changed the file extension to mpg. It is not an mpg file. I would use Xvid4PSP to change it to a more Vegas friendly format (DV AVI is best) and go from there.
Read my blog here.
Thanks. I tried converting it to all the lossless/less lossy AVI codecs and when I try to import Vegas only sees the audio track, not the video. I'm not a fan of using youtube videos since they weren't meant to be usd this way. I already told the person that I might not be able to include this so it's not a huge deal. I just figured I'd try what I could to make it work.
Clips cut from DVD can't be imported into Vegas, WHY?
By dora in forum DVD RippingReplies: 4Last Post: 8th Jan 2009, 19:04 -
Sony Vegas 7 doesn't let *.mov & *.avi files be imported into project..
By koldun in forum EditingReplies: 5Last Post: 1st Jul 2008, 16:04 -
Replace imported footage in Premiere Pro?
By Colmino in forum EditingReplies: 3Last Post: 9th Jun 2008, 06:37 -
Synced video and audio file imported into Vegas 7 becomes out of sync
By socool135 in forum EditingReplies: 1Last Post: 20th Jan 2008, 04:00 -
Is there a maximum resolution or size for jpgs imported into Vegas 7?
By nzo in forum Newbie / General discussionsReplies: 2Last Post: 8th Oct 2007, 21:18
