hi, when im online using my wireless router the connection terminates itself sometimes and doesnt reconnect. When I search for networks my router comes up with a full signal and when I click connect it shows "windows cannot connect", I then click diagnose the problem then just get the 2 options... "information on troubleshooting low wireless signal quality problems" or "view available networks".
It doesnt help at all![]()
I usually get around this by shutting down and wait till the next day and it works but I cant keep doing that.
any ideas?
heres info in event viewer if anyone understands it.
Code:Log Name: System Source: Microsoft-Windows-Diagnostics-Networking Date: 15/11/2008 22:08:34 Event ID: 6100 Task Category: (12) Level: Information Keywords: (2) User: LOCAL SERVICE Computer: VIJAY Description: Helper Class (RNWF MSM Helper Class) Event: Wireless Diagnostic Helper Class Event For complete information about this session see the Wireless Diagnostic Informational Event. Helper Class: Native WiFi MSM Initialize status: Success Information for connection being diagnosed Interface GUID: 00da5eed-6a79-4e8f-a234-ac2d65887997 Interface name: Intel(R) Wireless WiFi Link 4965AGN Interface type: Native WiFi Profile: Shady SSID: Shady SSID length: 5 Connection mode: Infra Security: Yes Connect even if network is not broadcasting: No Result of diagnosis: Problem found Root cause: Windows cannot connect to "Shady" Wireless association failed because Windows did not receive any response from the wireless router or access point. Detailed root cause: Wireless association to this network failed. Windows did not receive any response from the wireless router or accesspoint. Repair option: Click for information on troubleshooting low wireless signal quality problems Event Verbosity:0 Event Xml: <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event"> <System> <Provider Name="Microsoft-Windows-Diagnostics-Networking" Guid="{36c23e18-0e66-11d9-bbeb-505054503030}" /> <EventID>6100</EventID> <Version>0</Version> <Level>4</Level> <Task>12</Task> <Opcode>0</Opcode> <Keywords>0x4000000000000002</Keywords> <TimeCreated SystemTime="2008-11-15T22:08:34.154Z" /> <EventRecordID>56449</EventRecordID> <Correlation ActivityID="{D4FD7C88-B3A6-4444-9E8C-1702ADC6B1B1}" /> <Execution ProcessID="6924" ThreadID="7892" /> <Channel>System</Channel> <Computer>VIJAY</Computer> <Security UserID="S-1-5-19" /> </System> <EventData> <Data Name="HelperClassName">RNWF MSM Helper Class</Data> <Data Name="EventDescription">Wireless Diagnostic Helper Class Event For complete information about this session see the Wireless Diagnostic Informational Event. Helper Class: Native WiFi MSM Initialize status: Success Information for connection being diagnosed Interface GUID: 00da5eed-6a79-4e8f-a234-ac2d65887997 Interface name: Intel(R) Wireless WiFi Link 4965AGN Interface type: Native WiFi Profile: Shady SSID: Shady SSID length: 5 Connection mode: Infra Security: Yes Connect even if network is not broadcasting: No Result of diagnosis: Problem found Root cause: Windows cannot connect to "Shady" Wireless association failed because Windows did not receive any response from the wireless router or access point. Detailed root cause: Wireless association to this network failed. Windows did not receive any response from the wireless router or accesspoint. Repair option: Click for information on troubleshooting low wireless signal quality problems </Data> <Data Name="EventVerbosity">0</Data> </EventData> </Event>
Try changing your wireless channel in the router. You may be getting interference from a nearby router on the same channel. There should be about 11 channels available. Your PC will adjust to the change automatically. I have to do this at times with my wireless router when new people move into the neighborhood.
I'm also assuming you have good signal strength.
You might also check 'Connect even if network is not broadcasting: No' and change that to yes. That sometimes helps. That setting is in your 'Wireless Properties'. I also check 'Connect automatically when this network is in range'.
I've also just rebooted my laptop and it seems fix the signal loss problem for a while. -
I unplugged the ethernet cable, tried to connect to see if it was fixed but it wasnt.
I then changed the channel from 11 to 3 and unplugged the ethernet cable and the wi-fi connected straight away so thanks
btw me changing the channel isnt gonna affect or change anything is it? -
Changing the channel has never seemed to have any effects on the PC end. That's now the first thing I try if a PC reboot doesn't clear it up. Sometimes routers are set by default on certain channels and if your neighbor happened to have the same brand, interference can happen. It could also be some other kind of RF interference. But changing the channel is easy enough to try.
Wireless Network for Multimedia
By DarrellS in forum Media Center PC / MediaCentersReplies: 0Last Post: 19th Feb 2011, 00:22 -
windows 7 with wireless network problem
By mysts in forum ComputerReplies: 1Last Post: 17th Oct 2009, 11:42 -
How do I protect my wireless network from my neighbors?
By Xenogear900 in forum ComputerReplies: 15Last Post: 4th Dec 2007, 19:33 -
how to limit speed of users on wireless network (router-lan-wireless)
By deejay.2001 in forum ComputerReplies: 5Last Post: 2nd Nov 2007, 23:56 -
xbox-1 wireless network?
By stackner in forum ComputerReplies: 1Last Post: 21st Jul 2007, 04:25
