I've been getting my Asus v6800 Deluxe capture card up and running for the first time(what a pain!). Does anyone know if it makes any difference what resolution windows runs at when I capture?. Also I get wierd audio hiccups every 30-45 seconds when capturing. That and the video + audio get very badly out of sync after an hour(I think the how-to from Phat J can help me there) Is it from my sound card, or from disk I/O? I have a cmedia 8738 sound card, and I have DMA enabled. I know its a pos soundcard, but will a new one cure the hiccups? Thanks for any pointers anyone. Awesome website!
i would suggest capturing at the lowest resolution you can, say 640x480, because the higher resolution you have set through windows the more the toll it takes on your system resources, which is an intregal part of having a no-dropped frame capture...
Windows 7 desktop icons
By dfisher052 in forum ComputerReplies: 3Last Post: 30th Mar 2011, 10:55 -
same resolution but difference in display w.r.t. height and width
By Pravz in forum Video ConversionReplies: 8Last Post: 2nd Sep 2010, 01:03 -
Desktop Wallpapers - drained of resolution and diffuse
By orfajackson in forum Newbie / General discussionsReplies: 2Last Post: 25th May 2009, 04:20 -
Windows XP desktop keeps reverting to Default
By DarrellS in forum ComputerReplies: 11Last Post: 2nd Aug 2008, 09:39 -
Windows 3.1 Desktop
By wulf109 in forum ComputerReplies: 3Last Post: 18th Jun 2008, 17:23
