I'm trying to convert the VOR files captured on a Panasonic VDT-D310 mini DVD cam to the DV format using ffmpegX.
I've installed as per the details on the website including the three file installation.
When run the VOR input file to DV conversion it fails immediately with this error message in the log file.
Input #0, mpeg, from '/Users/X/Desktop/HouseDance2008_Original FIles/VR_MOVIE.VRO':
Duration: 00:04:40.8, start: 0.262222, bitrate: 8179 kb/s
Stream #0.0: Video: mpeg2video, 704x576, 25.00 fps
Stream #0.1: Audio: ac3, 48000 Hz, stereo, 256 kb/s
Output #0, dv, to '/Users/X/Desktop/HouseDance2008_Original FIles/VR_MOVIE.VRO.ff.dv':
Stream #0.0: Video: dvvideo, 704x576, 25.00 fps, q=2-15, 940 kb/s
Stream #0.1: Audio: pcm_s16le, 48000 Hz, stereo, 1536 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
bench: utime=0.007s
[dv @ 0x399490]Can't initialize DV format!
Make sure that you supply exactly two streams:
video: 25fps or 29.97fps, audio: 2ch/48Khz/PCM
Could not write header for output file #0 (incorrect codec parameters ?)
Encoding completed on Sat Nov 15 12:48:14 GMT 2008
Can anyone point out my error or suggest any settings which they know work please, this has got me stumped.
Many thanks..
