i am interested in a tuner card for a Vista HTPC build, and this card is available from newegg.com for $119 for 2 more days!.. anyone have any experience with this new card yet?
I am just a worthless liar,
I am just an imbecil -
I have tried it. I purchased it directly from hauppauge. It is an ok tuner but if you want to do qam it doesn't work. I
worked with tech support for about 2 weeks and I finally wound up sending it back to them. I even tried the vista fiji
tv pack and it didnt work. I purchased the avermedia m780 and that does just as well and is cheaper. It has 2
tuners and both are hardware encoders and works fine for qam with the vista fiji qam. They may have gotten new
software for the hauppauge but as of 3 weeks ago it still wasn't working. I am told that the beta version of
beyond tv 4.9 will work with the qam but I wasn't able to find it for download since I am not a beta tester.
Hope that helps. -
I have a hauppuage 1250 and its QAM tuner works with my cable system.
You should be aware that very few digital channels will be available via clear QAM -- typically those you can get via local over-the-air broadcast (required by the FCC). Most others are likely to be encrypted.
Also, note that QAM capture cards simply save the broadcast MPEG transport stream. You don't have any choice of bitrates or file sizes. -
i don't have digital cable, only standard.. so lack of QAM shouldn't be a problem for me, correct?
Yes, you should be able to record via the analog cable tuners. Only premium subscription channels like HBO and Cinemax are likely to be encrypted.Originally Posted by TooLFooL
I tried, it is quite nice, but you need a cable to use it
_____________________________
Digeus Solutions. Speed Up System
Hauppauge 2250 Tuner Card Aborts Recordings
By rixware in forum Capturing and VCRReplies: 8Last Post: 30th Jul 2012, 13:14 -
Just installed hauppauge 2250 dual tunser viseo card need some help & info
By case310350 in forum Capturing and VCRReplies: 1Last Post: 12th Mar 2011, 11:47 -
WinTV-HVR-2250 TV Tuner
By Richintx in forum Capturing and VCRReplies: 18Last Post: 23rd Mar 2010, 00:36 -
WinTV-HVR-2250 Model 1213, first impressions, great card! ... [SUCCESS]
By vhelp in forum Capturing and VCRReplies: 6Last Post: 27th Jan 2010, 23:12 -
Hauppauge HVR 2250 won't work with PCIE 2.0
By latichever in forum Capturing and VCRReplies: 1Last Post: 15th Sep 2009, 09:18
