Does Adobe's Premiere Pro CS3 readily support MPEG-2 file imports for editing?
On the legal registered copy, yes. Some of the bootlegs apparently have troubles. I would not know, I bought mine. It works perfectly, always has.
Yes, I capture all my videos at the office in MPEG-2 and import them into Premiere, they have always worked fine.
Only caveat, MPEG-2 will always be decoded to RGB through Premiere even for a cut. Premiere does not support "smart render" except with the expensive Mainconcept MPeg plug-in. Same goes for Vegas, AVID, FCP, etc.
Vegas Pro 8 will support Mainconcept's smart render only when input and output MPeg2 properties are identical and the project setting matches for resolution and frame rate.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Adobe Premiere Pro CS3 & Vegas Pro help
By KS89 in forum EditingReplies: 1Last Post: 8th Sep 2009, 22:52 -
SxS Pro card file MXF to DVD using Adobe Premiere Pro CS3
By Fary4u in forum Video ConversionReplies: 8Last Post: 20th Jul 2009, 09:00 -
logitech pro 9000 captured video to premiere pro CS3?
By yunakokimama in forum EditingReplies: 1Last Post: 15th Oct 2008, 16:27 -
Going from premiere 1.5 Pro to CS3 Pro - Working with a new Canon HV-20
By Tumbo in forum Newbie / General discussionsReplies: 26Last Post: 24th Apr 2008, 16:25 -
Importing a Photoshop CS3 image into Premiere Pro CS3
By paulinnorway in forum EditingReplies: 4Last Post: 17th Apr 2008, 07:54
