I have some old 8mm analog tapes that i want to put on dvd. I have a sony digital 8 camcorder that will play them back just fine on my tv, but when I try to copy them to my computer, it stops in imovie after one minute (and doesnt capture anything). I have successfully copied the digital videos taken by the digital 8 camcorder to the computer using the same firewire, but it wont work with the other. I had read some other posts, thinking this would be my solution. Am I doing something wrong? Do i need to switch settings, get a different kind of firewire? I have a dynex 6 pin to 4 pin (recommended by a person at best buy). Please help!
try something else to capure it
look in tools on the left menu -
thanks, zoobie, for responding so quickly. I looked at the tools on the left, but I guess, since I really don't know what I am doing, I don't even know where to start. I looked under capture a bit, and also in Mac, but was not sure really what to look for. So are you telling me that the firewire I bought will not work for this, and it is not just a setting or something on my camcorder/computer? It seemed in other forums, that this was the solution for many people. They actually bought a camcorder like this so they could playback their old 8mm videos, the firewire, and then it worked. I may use some of the words correctly, but I hardly know what I am talking about, sorry.. you will have to go slow...
Since you are using a Mac, probably better asked in our Mac Forum. Moving you.
And welcome to our forums.
Capture Analog 8mm Video 8 Tapes to DV - What equip will produce best Qual
By koop in forum Capturing and VCRReplies: 7Last Post: 5th Apr 2012, 00:36 -
Decent econmical way for converting 8mm (analog) video to H.264 files?
By salils in forum Capturing and VCRReplies: 5Last Post: 26th Dec 2011, 16:17 -
Best way to convert analog 8mm tapes to digital
By charliedog in forum Newbie / General discussionsReplies: 7Last Post: 29th Nov 2011, 03:15 -
How can I transfer CCD V5000 Hi8 Analog Video to digital/MAC to edit?
By thebird in forum Newbie / General discussionsReplies: 0Last Post: 15th Apr 2009, 05:36 -
Analog to digital pass through with Sony Handycam DCR- HC65
By Gerald Sr. in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2008, 00:18
