I hope someone can help me because I'm going to pull my hair out over this simple task. I bought a Canon DC 100 camcorder so I could make home movies and put vids up on youtube. I made a movie on my DC 100 and finalized the disk. I can put the disk in my DVD drive and I can play it with VLC player. THere is no problem with this. I would like to take my .vob, edit it and post it. I have , by default, Windows Movie Maker and I have Adobe Element Premier 1.0. I can take my VOB and copy it to my desktop and rename it to mpg but when I drag and drop it into Element its only 4 seconds long and no sound. So I downloaded Virtualdub to mpeg2 and try to convert to mpeg2 but the file is HUGE. I stop it after it get to 25 GIG...wow. All I want to do is take my video I made, edit it (with sound) and post it on youtube. Could someone please help me. I will be indebt to you forever.
DVD was never meant as a video editing format so that is why it's tricky to edit with most "older" editors.
But you can try export as dv-avi in virtualdub instead of uncompressed, under video->compression(install the Panasonic DV Codec if you have no dv-codec). Or use a dvd mpeg2 editor like mpeg video wizard.
AND PLEASE PLEASE use a better subject. I changed it this time. -
sounds interesting :POriginally Posted by derek12b
You should start with VOB2MPG, then for YouTube conversion try ffmpeg. There are a few programs which offer gui for it, and templates for the conversion. I use following command line parameters which you can save as a batch file:
-qscale: usable values for YouTube are between 6 and 9, lower is better but produces larger file.Code:ffmpeg -i your_file.mpg -ar 22050 -ab 96k -ac 1 -f flv -s 320×240 -qscale 9 youtube_video.flv
-s: you may increase resolution of your video up to 640x480 max. allowed
Hope it helps. -
Baldrick's suggestion is best when you want to edit with Premiere Elements, because DV-AVI is the best format for that -- and most other -- editors.
If, by chance, you are only making simple, cuts-only edits, you might try chopping up your VOB with MPG2Cut2 (freeware). Otherwise, stick with the VirtualDub > Premiere Elements option.
To convert your final edited video to a YouTube-friendly flv format, a free and easy tool is WinFF. -
I so appreciate all your advice and you taking the time to give me a 101 on the subject. Dont get me wrong I am more confused than ever but I will try to figure it out.
Simple DVD edit Please Help
By meks85 in forum Authoring (DVD)Replies: 3Last Post: 1st Feb 2010, 03:00 -
DVD edit, simple please help
By meks85 in forum Newbie / General discussionsReplies: 1Last Post: 31st Jan 2010, 18:59 -
How do i put my youtube vids onto dvd? :-(
By MADRASTA84 in forum Newbie / General discussionsReplies: 4Last Post: 12th Nov 2009, 06:41 -
A simple, no fuss way to prepare clips from a DVD to upload to YouTube
By G)-(OST in forum User guidesReplies: 9Last Post: 10th Nov 2009, 22:35 -
Is it possible to put YouTube videos on DVD?
By chithanh119 in forum Video ConversionReplies: 3Last Post: 21st Dec 2008, 04:55
