So heres the deal.
I have some home video footage thats on a DVD but the person who did the original transfer left a lot of trailing black at the end (about 2 hours haha)
I've already ripped the files to my computer (with Mac The Ripper) and I want to trim out the black bits and then re-burn to DVD... without losing quality.
I know I could use MPEG Streamclip to trim, but not sure where to go from there... I could do what I normally do -- export as .mov with DV compression but that will result in a huge file thats only going to get recompressed...
so it seems silly to go that route.
I was reading the help and I thought de-mux might work but when I put them into Toast they show up as two seperate files rather than one (like it said it would).
I have both Toast and DVD Studio Pro (though DVDSP might be overkill?).
Any thought? thanks in advanced!
:: ehmjay.
Originally Posted by ehmjay
okay - which demux should I use? regular? headed? unscaled?
thanks for the quick response.:: ehmjay. -
I always use 'regular' demux in MPEG Streamclip, without problems.
But honestly I wouldn't know what the others are for. -
i usually just save as vob and it works fine, but not always on toast..i somtimes have to use mpeg2works to make a dvd ready disc image...
Originally Posted by pixel zombie:: ehmjay.
352x480 is a legal DVD resolution, so it could be right. Verify the source resolution with MediaInfo Mac and a secondary tool (e.g. MPEG Streamclip's Show Stream Info) to be sure.
How do I rip a DVD, trim part of it (beginning & end), and copy onto DVDs?
By aple in forum Newbie / General discussionsReplies: 5Last Post: 11th Jul 2011, 18:04 -
Need one app to trim, crop, menu, chapter and author to DVD... in batch!
By bhershey in forum Authoring (DVD)Replies: 4Last Post: 24th Mar 2011, 12:06 -
How do I clean up (trim) beginning and end of DVD?
By perceptionist in forum EditingReplies: 6Last Post: 28th Mar 2010, 00:29 -
How to trim wmv-hd?
By daz2712 in forum Blu-ray RippingReplies: 2Last Post: 26th Aug 2009, 09:55 -
Convert non-compliant VOBs to "good VOBs"
By pmolson in forum Video ConversionReplies: 3Last Post: 24th Oct 2008, 10:52
