When trying to convert movies I have encountered alot of problems with the sound becoming offtrack and end up with something like the old B rated Japanese movies where the words come out after the lips stop moving.
I am not very familar with audio codecs or any programs dealing with them. I was hoping some of you might have suggestions or recommendations.
The programs I usually use are.....
Windows Movie Maker
Movavi VideoSuite 3.4
Super DVD Creator.
Any suggestions?
Movies is not a very descriptive term. What format are these movies? What is the extension (xxxxx.ext)?
I changed your subject so it better describes the topic.
Yep, give us more information! What is the source and what are you converting to? -
Some generic suggestions.
Seperate the audio from the video as early in the process as possible.
Save the audio as a WAV file, eliminating VBR encoding which is the most common cause of this problem with downloaded movies.
VirtuadDub. Get it. Use it. You will find it a very valuable tool.
Encode seperately.
Do not trust playback results from most software. Author into VOB files, play these from the hard drive before burning. -
Ok let me see if I can explain this. Bear with me.
My most recent project is a old tv series that I downloaded. The video clip I downloaded is in the avi format. The sound is fine with this first downloaded clip. Here is the properties listed for it when I right hand click on it.
Audio
Bit rate 131kbps
Audio format MPEG Layer-3
Video
Frame rate 23 frames /sec
Data rate 1222kbps
video sample size 12 bit
video compression XVID
Ok what I want to do is to burn it to dvd to be played on my tv. The program I normally use for this is Super DVD Creator. Even tho I do have the xvid codec installed for some reason this program did not recongize that video format. So what I did was to convert it to wmv format using the Windows Movie Maker. This is what the properties show for that version of the clip.....which the sound is messed up in it.
Audio
Bit Rate 1855 kbps
Audio sample size 16 bit
channels 2 stereo
Audio sample rate 44kHz
Video
data rate 593kbps
video sample size 24bit
stream rate video 2
So what am I doing wrong and...... in laymans terms......correct it.
Thanks in advance to those who are trying to help me. -
Just try use something better to convert to dvd like ConvertXtoDVD or the free DVD Flick. They should handle downloaded material much better then most crappy converters.
super is great program for many tasks
but I NEVER use it to create a DVD
depending, where the source avi's come from
they might be 23.976 fps or 25 fps, very unlikely they are 29.976 / 30 fps
so to convert for TV , extra frames are created during the process this messes with the conversion of the VBR MP3 sound track timing
if you want to use an all in one, try convertxTOdvd
edited for clarity, remove typo
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 11:58 -
sound offtrack
By maverickboy2007 in forum Newbie / General discussionsReplies: 1Last Post: 11th Jul 2009, 08:26 -
Need also expert advice about video and sound files!!
By vantechmag in forum EditingReplies: 8Last Post: 14th May 2009, 10:48 -
Advice Req: Filtering Audio Files For A Clearer Sound
By Teac23 in forum AudioReplies: 2Last Post: 27th Nov 2008, 09:43 -
Sound Advice
By mark1411 in forum AudioReplies: 3Last Post: 12th Nov 2008, 21:09
