Hey guys, I'm new here and wondering if this was possible. Is it possible to split an HDMI feed, so I can keep 1 HDMI connection to my TV, and have the other S-Video or Composite connection so I can connect to my standard def capture device? I'm primarily trying to record from my Xbox, but I'd like to keep the HD feed going to the TV. Thanks in advance.
No. Xbox does HD or SD not both.
If you export analog components and buy a component distribution amp, you could feed a HAVA Platinum HD box plus monitor. It will downscale HD to SD for recording.
http://www.skywalker.com/images/image/CHO4055.jpg
http://www.myhava.com/products.htmlRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
HDMI, Composite Input to LCD Monitor
By vasudevanb in forum Newbie / General discussionsReplies: 1Last Post: 8th May 2010, 21:54 -
Composite to HDMI/DVI/component Conversion
By Gromit137 in forum DVB / IPTVReplies: 3Last Post: 30th Oct 2008, 12:10 -
Canopus AceDVio composite capture problem (Svid works, but not composite)
By bfrandse in forum Capturing and VCRReplies: 3Last Post: 28th Oct 2008, 11:55 -
vga, dvi-hdmi, or svideo best cable for pc to 720p hdtv?
By yoda313 in forum ComputerReplies: 5Last Post: 12th Nov 2007, 21:37 -
Philips DVP5960 HDCP Question /// HDMI -> DVI and Composite Audio?
By cactusPhone in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th May 2007, 23:32
